1978 KZ1000 Starter clutch question
  • Skiprrdog
  • Skiprrdog's Avatar Topic Author
  • "Are we there yet?"
Re: 1978 KZ1000 Starter clutch question
21 Sep 2015 16:26
#691258
Yeah, I am not too worried about the ball bearing (yet) I am going to head out tomorrow and see if I can rent/buy a puller that will work.
swest wrote: Take a rod and tap on the ball bearing until it gets loose. What you need is a puller that screws on. I used lock tight on a old rotor I thought was wobbling. I had to heat it up until the pressure of the bolt popped it off.
1983 KZ1100 A-3 Shaft
1976 KZ900
1975 H2 Triple
1984 Yamaha XJ900 Seca
1984 Harley Davidson FXRDG
#BlackBikesMatter
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Sep 2015 16:43
#691259
I'm not saying beat on it. Just a light tapping to dislodge it.
  • Skiprrdog
21 Sep 2015 18:15
#691269
Thanks for talking me down there... cause right about now i feel like beating on it :evil:
I saw this gear puller on O'Reillys site... only $6.00... going to look at it tomorrow
Attachment w141.jpg not found
and see if it will work.
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Sep 2015 18:22
#691272
  • missionkz
  • missionkz's Avatar
21 Sep 2015 20:27
#691279
Skiprrdog wrote: Thanks for talking me down there... cause right about now i feel like beating on it :evil:
I think it is junk! I bet those arms will bend and pop right off.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • floivanus
  • floivanus's Avatar
21 Sep 2015 22:54
#691281
Just use the right tool, before you mess something up (like getting a ball bearing jammed in there) the tool with the puller arms will mess up the outside of the rotor, and the ball bearing has a chance to gall up the crank threads or just get stuck in there. I have done a few stubborn ones with an impact gun and a hammer, tighten bolt down a bit, then smack with hammer, tighten again smack again. Bit excessive tho.
Past; 78 kz1000, 83 kz550
Andrew
  • KZB2 650
  • KZB2 650's Avatar
22 Sep 2015 02:24
#691291
Good luck with all this ..... maybe my starter clutch repair wasn't so bad after all ....... and I just gotta say I love the bike still my favorite year and model. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Skiprrdog
22 Sep 2015 07:07
#691340
Yeah, after sleeping on it you guys are probably right...I went ahead and ordered the Motion Pro 16mm bolt to take it out with. Now the hard part will be staying out of the garage and away from the motorcycle until the tool gets here B)
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • Skiprrdog
22 Sep 2015 17:50
#691456
Funny what you can find in your own tool box sometimes. I found this puller, Looked at the black bolt in the middle and thought gee, that looks familiar. It is 16mm, and must be the same pitch as inside the rotor, as it will thread in. It is hardened, I think all I would need to do is grind down the little nib on the end. I already ordered the Motion Pro one, but dang, I want to *work* on that bike :laugh:
Attachment IMG_0969.jpg not found
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Sep 2015 18:38
#691461
Why grind off that nib on the end? It won't bother anything.
  • Skiprrdog
29 Sep 2015 10:24
#692510
Well, I got that rotor off yesterday! The three allen bolts were not loose, so that was not the problem. All three of the springs were different lengths, and one of the three rollers had some *mild* looking wear on it. Not sure what the cutoff for good/no-good is, so I ordered a rebuild kit for it. The big gear on the back of the assembly did not look too bad, but then I found a guy on fleaBay that had one, new old stock, still in the Kawasaki packaging for $65.00 with free shipping, soooo, not wanting to do this again any time soon (if ever) I got one.
Question; the rubber damper, on mine it is pretty hard, more like plastic, so I assume I should replace it also. How do I know which of the three to get?
Skip
Attachment IMG_0985.jpg not found
Attachment IMG_0992.jpg not found
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
  • Skiprrdog
29 Sep 2015 10:55
#692514
No eBay APP ID and/or Cert ID defined in Kunena configurationIn case anyone needs one of these gears, it looks like the seller has one or more left...
Attachment KGrHqRogFHFeDyhBRy0EzJ3sw60_57.jpg not found
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
