'82 GPz incorrect coils?
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
11 Sep 2015 02:37 - 11 Sep 2015 04:03
#689566
I'm having power loss issues with my 82 GPz750 so I was testing my ignition system. I'm getting a reading of approx 5Ω when the FSM specifies 3Ω. I know you can get 5Ω coils so I don't know if these are bad or if they have been changed and if they might be part of my issue.
I'm also trying to figure out if I'm having issues with the rest of my ignition. the pickup coils are showing the correct resistance but the ground readings are strange, I've checked a couple of times and sometimes it shows open and other times I'm getting a resistance reading. I haven't tested with heat yet.
I'm a bit of a dope when it comes to electrical and so I just want to make sure I'm reading things right.I haven't tested my ingniter yet because i was confused about the procedure.
Last edit: 11 Sep 2015 04:03 by GPzMOD750.
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: '82 GPz incorrect coils?
11 Sep 2015 03:43
#689572
I think 5 Ohm were for the earlier points ignition, later transistorised type had lower resistance coils. I had one coil go on mine, using a meter to test resistances isn't a certain way to tell a bad coil.
I've noticed the pick-ups resistance outside FSM specs but they work fine. The 4 way Hitachi mini block connt4ector and terminals can be easily changed.
New 7mm non resistor HT wire and caps usually makes a difference on old bikes, easy job.
  • GPzMOD750
Re: Re:'82 GPz incorrect coils?
11 Sep 2015 03:55 - 11 Sep 2015 04:04
#689574
So, I most likely have coils for a points system without the points. That doesn't sound good. I didn't think to check the condition of the connectors themselves but they didn't seem to show any indication off damage.
Last edit: 11 Sep 2015 04:04 by GPzMOD750.
  • Tyrell Corp
11 Sep 2015 04:06
#689576
...I didn't think to check the condition of the connectors themselves but they didn't seem to show any indication off damage
:side:
  • GPzMOD750
11 Sep 2015 05:22 - 11 Sep 2015 06:09
#689582
No eBay APP ID and/or Cert ID defined in Kunena configurationTouché.
I'll find some connectors then. Should I replace the coils with 3Ω or maybe get a Maxi-dwell system?
Last edit: 11 Sep 2015 06:09 by GPzMOD750.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Sep 2015 06:10
#689590
I had one like that in the 70's. I still have it laying in my junk pile. GM style points, etc. The switch broke early on. I'd get a Dyna S and be done with it. About the same price.
  • GPzMOD750
11 Sep 2015 06:23
#689593
swest wrote: I had one like that in the 70's. I still have it laying in my junk pile. GM style points, etc. The switch broke early on. I'd get a Dyna S and be done with it. About the same price.
The big question is would I be done with it?
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Sep 2015 06:38
#689594
I put mine on two years ago. I still carry the points plate and cam just because I like to be prepared. It's under my seat with spare coils. I don't think I'll ever be done with my bike. Not because it's undependable, I like adding more goodies. :woohoo:
  • GPzMOD750
11 Sep 2015 07:13
#689597
I'm still concerned that the ignition coils are wrong.
Do you have to do anything igniter wise?
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Sep 2015 07:55
#689599
It bypasses the igniter. It will work with 3-5 OHM coils.
The following user(s) said Thank You: GPzMOD750
  • JR
  • JR's Avatar
11 Sep 2015 09:06
#689602
Are you measuring resistance by probing through the plug caps? Many plug caps have a built in resistor. Sometimes these resistors break down. Always measure coil resistance with plug caps - or better yet caps plus wires - removed.
  • GPzMOD750
Re: Re:Re:'82 GPz incorrect coils?
11 Sep 2015 09:55
#689606
swest wrote: It bypasses the igniter. It will work with 3-5 OHM coils.
Well then, sign me up.
