No spark stump the chump
  • Topper
  • Topper's Avatar Topic Author
Re: No spark stump the chump
09 Sep 2015 03:02
#689269
I doubt it's timing, but I'll check that when I get home. Bike was running well when parked about a month ago. It sat for a few weeks and then wouldn't start. I doubt timing could get off in that scenario. But like I said, I'm stumped. It seemed reasonable that the condenser could fail and it apparently had.
I'm most concerned about the visible spark jumping the points. I know I've seen that before on the bike and figured it was normal, because everything else was going fine. But based on the comments in this post and what I see in my manual I gather that's not normal.
I'll have to wait a few days until the new set of points arrives to see if swapping those out has any effect.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2015 03:20
#689274
You can use a points or finger nail file. I use a folded match book to clean them. Could be just oil or grit.
  • Tyrell Corp
  • Tyrell Corp's Avatar
09 Sep 2015 04:17
#689281
The condenser is there to prevent arcing at the points, if working right.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2015 04:26
#689286
He replaced them. :S I used two early Ford condensers up stream when I was having the same problem. $5 a piece a AZ. Could there be A/C in the system caused by a bad rectifier?
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2015 04:33
#689288
As I remember it, I was boiling the batteries and got a used regulator from a dead Z1. Always had a strange miss. I parked it in 98 and put in a modern R/R unit this time around. I figured I had a bad diode in the rectifier.
  • LineArtist
  • LineArtist's Avatar
09 Sep 2015 18:23 - 09 Sep 2015 18:25
#689419
Boil over from a bad rec/reg will increase voltage from the battery to the coils when running and fry a condenser and points (and other things). Equally if a 4 Ohm coil specification is reading 2 Ohms, more juice is getting to the condensers and points and causing them to fry.
Have you tested coils (primary and secondary), caps, plugs and condensers for spec operating range? And if you get it started get a voltage read on the battery, the rec/reg will keep it under a certain number (around 15 or less volts), If it climbs the rec/reg needs to be replaced. If it drops you may have a stator problem.
Timing, only because I just went through a similar diagnosis and it was the last thing I checked - should have been the first. I'm sure you can run a search for "static timing method" here and find the process without running the engine.
Good luck - you will get there.
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
Last edit: 09 Sep 2015 18:25 by LineArtist.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Sep 2015 19:03
#689423
Crap, I had a point bloc loosen up on me while I was racing a cute blond 30 years ago. I pulled over, set it by eye and went on my way. B)
The blond turned out to be breeder and put out 5 kids in so many years. :ohmy:
Dodged a bullet on that one. :whistle:
  • Topper
12 Sep 2015 05:48 - 12 Sep 2015 05:50
#689722
Quick update. Still waiting on my points but managed to get the bike started today. Running strong but the points are still sparking.
I just noticed that the new condenser I installed is the wrong part number. It's the condenser for a '76-'77 KZ750. The '78-'79 had a different part number. (Mine's a '79).
Could that be the problem with the points arcing? The lead for the new condenser was too short, so I spliced in a little extra wire for it to reach. Any way to know whether the condenser itself was different for '78-'79 or if the part change was just the lead length?
I'll get the proper condenser just to be sure. I'm just wondering if that could explain the arcing or if there's something else going on.
1979 KZ750 Twin
Last edit: 12 Sep 2015 05:50 by Topper.
  • LineArtist
12 Sep 2015 06:41
#689727
You can cross reference the different years on a site like Z1 - chances are they are the same.
'79 KZ650B3 (stock)
'06 HD 883R
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Sep 2015 08:27
#689742
I doubt it. They are all the same as far as what they can handle. The Ford ones worked just as well if not better. Your points are ether pitted, oily or the spring is cockeyed.
  • Topper
18 Sep 2015 09:11
#690691
New points arrived and I'm up and running again. The points do still spark a little. Not as much as before. But I can see a spark arc across the points as they open.
1979 KZ750 Twin
  • EdVeilog
  • EdVeilog's Avatar
19 Sep 2015 09:00
#690846
This sounds familiar
when you mount the plate , you have to be very careful to insulate the pickup transformers from any possible grounding
Check your plate mounting you can use a piece cardboard to test the theory..
Just use a cereal box and scissors and cut an Insulator to put behind the plate !
