No spark stump the chump
  • Topper
  • Topper's Avatar Topic Author
Re: No spark stump the chump
05 Sep 2015 07:28
#688725
swest wrote: Usually the points will start sparking indicating the condensers are going bad.
I hadn't noticed any problems. Bike was running fine when I parked it. I hadn't visually observed the points in a while, so I don't know if I'd know whether they were sparking.
New points and condenser seems like the logical next step. I'll keep you posted.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Sep 2015 07:52
#688733
You could turn it over and watch the points. Sometimes a little grit or oil will foul them.
  • Topper
05 Sep 2015 08:27 - 05 Sep 2015 08:32
#688741
The points aren't sparking now. But I definitely have seen them spark in the past. At the time i thought that was normal. I'm rereading my manual now and see that's a sign of a failing condenser.
Thanks for putting me on the right track.
I think this chump is no longer stumped, but I'll have to wait for the parts before I can be sure.
1979 KZ750 Twin
Last edit: 05 Sep 2015 08:32 by Topper.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Sep 2015 08:33
#688744
If they were sparking, they may have been going bad. What bothers me is, there should be fire works now. Do you have 12V there now?
  • Topper
08 Sep 2015 14:57 - 08 Sep 2015 15:03
#689215
Ok, got my condenser. New points are still a couple days away according to USPS. I've got spark again, but I'm back to being stumped.
Spark plugs are sparking but so are my points.
You can see it tries to start (the tank was off and there was barely any gas in the carb bowls). Then you can see the points sparking.
I put the tank back on and filled the float bowls. It's still sparking at the points and still not starting.
Is sparking like this normal? It used to do this, but from what I read here and in the manual this kind of sparking is a sign of a failing condenser. Replaced the condenser, spark (at the plug and the points) came back.
1979 KZ750 Twin
Last edit: 08 Sep 2015 15:03 by Topper.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2015 16:08
#689222
Coils may have a short in them.
  • Topper
08 Sep 2015 16:47
#689226
Coil primary and secondary windings have passed the tests in the manual. The only test I couldn't figure out was the one that said you connect to the coil core. Can't figure out what that means.
1979 KZ750 Twin
  • missionkz
  • missionkz's Avatar
08 Sep 2015 16:59 - 08 Sep 2015 17:00
#689228
Pull the plug wire from the coil in question and put a screw driver into the boot.
Turn the engine over by hand until that coil's points are closed.
Use a small blade screwdriver at those same points to push them open and closed.
Turn the ignition on and hold the screwdriver which is stuffed in the plug boot, by its handle so you could see an arc from the screwdriver to engine/frame ground when you open and close those points.
If it fires a nice spark I think your coil is ok.
A good healthy battery and coil should be able to throw 1/4" to 3/8" long spark.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 08 Sep 2015 17:00 by missionkz.
  • Topper
08 Sep 2015 17:35
#689236
missionkz wrote: Pull the plug wire from the coil in question and put a screw driver into the boot.
This seems like basically the same test missionkz suggested. I ran his version and got a spark when I lifted the ground. Plugs seem to be sparking, but so are the points.
So I shouldn't see any sparking between the points?
1979 KZ750 Twin
  • LineArtist
  • LineArtist's Avatar
08 Sep 2015 17:36
#689237
Have you checked timing?
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
  • Topper
08 Sep 2015 17:47
#689238
Can't really check timing until I can get it running.
1979 KZ750 Twin
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2015 18:17
#689244
You can do it by making the points open when they just come to the F mark. It's rough but will work.
