New bike ...No spark
  • Vwnik
  • Vwnik's Avatar Topic Author
25 Jul 2015 11:37
#682687
New to being a bike owner!! Finally
I bought a 1980 kz250 project- cause it's not running. I have power to the ignition coil, bike turns over but no spark? It came with a universal 12v coil and it is getting hot. Is this my issue? Also when I flick the kill switch over it sends a spark?? Bizarre right.
Any ideas are much appreciated!!
  • MFolks
  • MFolks's Avatar
Re: New bike ...No spark
25 Jul 2015 19:34
#682740
Does the bike have ignition points, or electronic ignition? Do you have a shop manual? www.repairmanual.com is one place to get one.
  • TexasKZ
  • TexasKZ's Avatar
25 Jul 2015 20:48
#682747
Nice looking ride. Hopefully, this will be an easy fix and you can get on the road soon. As MFolks suggests, a genuine Kawasaki service manual will be the most important tool in your toolbox.
  • mike1957
  • mike1957's Avatar
25 Jul 2015 20:59 - 26 Jul 2015 07:14
#682752
Check your kill switch for shorted wires clean your contacts
on your switch.Take it from there check your coil,check your
plug wires ,points or the electronic ignition igniter,check yor spark plugs...Not sure what
type of igninion system you have? It's a process of elimination
hopefully you'll find the problem easy.Like every one says get a service manual.
mike1957
Last edit: 26 Jul 2015 07:14 by mike1957. Reason: typo
  • Vwnik
Re: Re:New bike ...No spark
25 Jul 2015 21:26
#682760
Yes- def need a shop manual. Feel like I'm blind without it, and have found 0 electronic ones or parts of one to use. It does have points and condenser. I've replaced the spark plug wire, took apart the switch and cleaned it all- test light shows power where it needs to be. Good power to the coil... Nothing from the coil. Only universal coils are available now for this model though... So are there recommended ones over others? I have a emgo unit on there now.
Thanks
  • mike1957
  • mike1957's Avatar
25 Jul 2015 22:08 - 26 Jul 2015 07:24
#682762
Check your points not sure what the gap is on your 250 ? My kz900
the gap is between 0.012 and 0 .016 see if the points are pitted
or need replacing..Found this online it refers to cars but
same as motorcycles.Try this first find the correct point gap.
and adjust or replace points.I'm not sure if one ignition coil
is better than a other as long as you have the right amount
of ohms you need .
www.glenngoodspeed.com/volvo/POINTS.HTM
mike1957
Last edit: 26 Jul 2015 07:24 by mike1957. Reason: typo
  • mike1957
  • mike1957's Avatar
26 Jul 2015 07:39 - 26 Jul 2015 07:41
#682791
You may also want to check the coil before buying a new one.Do you have a ohmmeter?
You need to check the primary and secondary resistance.I'm sure
there are other members here that can give you more iinformation
mike1957
Last edit: 26 Jul 2015 07:41 by mike1957. Reason: typo
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Jul 2015 07:44
#682792
See if you have power going to the points.
  • Vwnik
26 Jul 2015 09:29
#682801
Power on both posts of the coil (single coil bike, single post for single plug! Lol)
Power is going to the points if I don't have it screwed in place.. As soon as I attach it----power to that lead goes? Is this right?
  • missionkz
  • missionkz's Avatar
26 Jul 2015 10:18
#682811
Vwnik wrote: Power on both posts of the coil (single coil bike, single post for single plug! Lol)
Yes sort of... but only if the points are closed, shorted to ground somewhere at their mounting point or if the electrical connector(s) and springs are not insulated from the bracket.
The point's springs should be hot with 9.5vdc-12vdc when the points are open also. That is how the DC voltage is applied to the actual contact points from the coil's primary side. When closed, the coils charge up (and and get hot if charged all the time).
When the points open, the magnetic fields collapse and the coil's secondary discharges through the HT leads to the spark plugs.
If no VDC when the points are open, mounting them down is shorting them out to the chassis somehow.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Vwnik
26 Jul 2015 10:19
#682812
Lol wouldn't believe it--- po had the wire on the points installed wrong. It was sending power to the wrong side(powering the engine, which is the ground) duh. Bike is up and running. Just now have to set gap of points. Anyone know what this is?? No manual yet: it's in the mail
  • missionkz
26 Jul 2015 10:39 - 26 Jul 2015 10:39
#682817
Vwnik wrote: Lol wouldn't believe it--- po had the wire on the points installed wrong. It was sending power to the wrong side(powering the engine, which is the ground) duh. Bike is up and running. Just now have to set gap of points. Anyone know what this is?? No manual yet: it's in the mail
Cool!! Most all of the KZ engines with points use a point gap in the .014" range.
scontent.fsnc1-1.fna.fbcdn.net/hphotos-x...164723_2154980_o.jpg
Bruce
1977 KZ1000A1
Last edit: 26 Jul 2015 10:39 by missionkz.
