New bike ...No spark
- Vwnik
25 Jul 2015 11:37
New to being a bike owner!! Finally
I bought a 1980 kz250 project- cause it's not running. I have power to the ignition coil, bike turns over but no spark? It came with a universal 12v coil and it is getting hot. Is this my issue? Also when I flick the kill switch over it sends a spark?? Bizarre right.
Any ideas are much appreciated!!
- MFolks
Re: New bike ...No spark
25 Jul 2015 19:34
Does the bike have ignition points, or electronic ignition? Do you have a shop manual?
www.repairmanual.com
is one place to get one.
25 Jul 2015 20:48
Nice looking ride. Hopefully, this will be an easy fix and you can get on the road soon. As MFolks suggests, a genuine Kawasaki service manual will be the most important tool in your toolbox.
- mike1957
25 Jul 2015 20:59 - 26 Jul 2015 07:14
Check your kill switch for shorted wires clean your contacts
on your switch.Take it from there check your coil,check your
plug wires ,points or the electronic ignition igniter,check yor spark plugs...Not sure what
type of igninion system you have? It's a process of elimination
hopefully you'll find the problem easy.Like every one says get a service manual.
mike1957
Last edit: 26 Jul 2015 07:14 by mike1957. Reason: typo
- Vwnik
Re: Re:New bike ...No spark
25 Jul 2015 21:26
Yes- def need a shop manual. Feel like I'm blind without it, and have found 0 electronic ones or parts of one to use. It does have points and condenser. I've replaced the spark plug wire, took apart the switch and cleaned it all- test light shows power where it needs to be. Good power to the coil... Nothing from the coil. Only universal coils are available now for this model though... So are there recommended ones over others? I have a emgo unit on there now.
Thanks
Thanks
- mike1957
25 Jul 2015 22:08 - 26 Jul 2015 07:24
Check your points not sure what the gap is on your 250 ? My kz900
the gap is between 0.012 and 0 .016 see if the points are pitted
or need replacing..Found this online it refers to cars but
same as motorcycles.Try this first find the correct point gap.
and adjust or replace points.I'm not sure if one ignition coil
is better than a other as long as you have the right amount
of ohms you need .
www.glenngoodspeed.com/volvo/POINTS.HTM
of ohms you need .
mike1957
Last edit: 26 Jul 2015 07:24 by mike1957. Reason: typo
- mike1957
26 Jul 2015 07:39 - 26 Jul 2015 07:41
You may also want to check the coil before buying a new one.Do you have a ohmmeter?
You need to check the primary and secondary resistance.I'm sure
there are other members here that can give you more iinformation
mike1957
Last edit: 26 Jul 2015 07:41 by mike1957. Reason: typo
26 Jul 2015 07:44
See if you have power going to the points.
- Vwnik
26 Jul 2015 09:29
Power on both posts of the coil (single coil bike, single post for single plug! Lol)
Power is going to the points if I don't have it screwed in place.. As soon as I attach it----power to that lead goes? Is this right?
- missionkz
26 Jul 2015 10:18Yes sort of... but only if the points are closed, shorted to ground somewhere at their mounting point or if the electrical connector(s) and springs are not insulated from the bracket.Vwnik wrote: Power on both posts of the coil (single coil bike, single post for single plug! Lol)
The point's springs should be hot with 9.5vdc-12vdc when the points are open also. That is how the DC voltage is applied to the actual contact points from the coil's primary side. When closed, the coils charge up (and and get hot if charged all the time).
When the points open, the magnetic fields collapse and the coil's secondary discharges through the HT leads to the spark plugs.
If no VDC when the points are open, mounting them down is shorting them out to the chassis somehow.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Vwnik
26 Jul 2015 10:19
Lol wouldn't believe it--- po had the wire on the points installed wrong. It was sending power to the wrong side(powering the engine, which is the ground) duh. Bike is up and running. Just now have to set gap of points. Anyone know what this is?? No manual yet: it's in the mail
- missionkz
26 Jul 2015 10:39 - 26 Jul 2015 10:39Cool!! Most all of the KZ engines with points use a point gap in the .014" range.Vwnik wrote: Lol wouldn't believe it--- po had the wire on the points installed wrong. It was sending power to the wrong side(powering the engine, which is the ground) duh. Bike is up and running. Just now have to set gap of points. Anyone know what this is?? No manual yet: it's in the mail
scontent.fsnc1-1.fna.fbcdn.net/hphotos-x...164723_2154980_o.jpg
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 26 Jul 2015 10:39 by missionkz.
