Kz650 charging at 20-21 volts!!
  • Kmartcivic
  • Kmartcivic's Avatar Topic Author
15 Mar 2015 09:03
#664491
Hello everyone. My kz650 has gone through a lot. I had issues with it running good then falling on its face when I tried to take off. I figured it was electrical issues. The harness has been hacked up pretty good. So I decided to yank the whole harness and make a new one from scratch. The bike is kick start only. Running a ub1222 2.2aH battery. Led tail, turn signals and a led 30 watt h4 bulb. Dyna coils and dyna ignition. The stock regulator/rectifier crapped out on me about a year ago so I slapped in an ebay special China scooter regulator. Now I'm wondering if the cheap regulator just took a crap or is it something in my wiring. All new wire, new bullet connectors and waterproof connectors throughout. And this regulator is a 4 wire not a five. I ran the red wire (power) to the brown wire off the ignition harness. Should it be connected to the White instead? Would that make a difference or should I stop being so cheap and get a good regulator.?
2000 Yamaha Roadstar 1600
1970 Yamaha Hs1
1978 Honda CB750 Hondamatic
80 - KZ650 -Sold.
Re: Kz650 charging at 20-21 volts!!
15 Mar 2015 12:05
#664513
Yes. Buy a quality regulator. Contact the folks at the link below. I have been using one of their rectifiers on my KZ650 for several years now and it works perfectly. I'm sure their regulators are of the same high quality. Ed
www.oregonmotorcycleparts.com/Products.html
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Mar 2015 13:13
#664524
I just won a used reg/rect on eBay from a KZ 1000 MKii. It works but it is slow to charge until the revs get to 35/4000. I needed one and it was worth a shot. Was looking at a new one for $25 free shipping. Too cheap, don't trust it. I will but a new one when I can afford one. Need a chain and sprockets soon and tires always.
The brown wire goes to the instruments, the red/white one goes to the battery. You can fry your battery and other components. Get a good one.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Mar 2015 18:50 - 15 Mar 2015 18:53
#664552
The attachment came from The Old Kaw Man on the net. He has some Z1/KZ parts and has a good site. I bought a used Reg/Rect from him in 13. Had some bad connections and ruined it. He sold me a KZ 1000 rear fender for $45.
He's been very helpful.
Last edit: 15 Mar 2015 18:53 by SWest.
  • MFolks
  • MFolks's Avatar
15 Mar 2015 18:52
#664553
Are you using a Analog, or Digital multimeter to check the voltages? Some Digital meter are sensitive to magnetic fields, and may give a strange reading. If possible, borrow a Analog(moving needle, multimeter), and try again.
  • Kmartcivic
16 Mar 2015 06:07
#664575
Thanks guys. Yeah I'm using a digital multimeter. I still think it was high cause my horn sounded ridiculous and now my headlight went out. Think it burned it up. That's what I get for a 9 regulator. I plan to change the stator out for a 3 phase once I get some money.
1970 Yamaha Hs1
80 - KZ650 -Sold.
