I have a bad IC igniter what are my options?
  • lucienmaier
  • lucienmaier's Avatar Topic Author
03 Mar 2015 18:59
#663379
I have an 81 kz1000m csr that has a bad IG igniter.
Attachment 11034267_10155191003520332_3909318796145121793_n.jpg not found
What are the options for replacing this?
--1981 Kz1000m CSR--
--Converted to 1100CC---
  • lucienmaier
Re: I have a bad IC igniter what are my options?
03 Mar 2015 19:00
#663380
I found this? Would it be a better option than stock off ebay?
www.z1enterprises.com/ItemDetails.aspx?i...dule%29&item=DYDBR-2
  • loudhvx
  • loudhvx's Avatar
03 Mar 2015 22:40 - 03 Mar 2015 22:44
#663407
That booster is for use with points.
You can make an igniter for about $40. I've been using this one for over 10 years:
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
Are you sure everything else is functioning?
Last edit: 03 Mar 2015 22:44 by loudhvx.
  • Nessism
  • Nessism's Avatar
04 Mar 2015 05:49 - 04 Mar 2015 05:50
#663418
Ignitors are readily available on ebay. Of course the 1000 version are about double the cost of the 750 model, and likely near identical, but that's another matter. Converting to something more modern, like a Dyna S, is also an option. It will work fine with your stock coils so all you need is the unit itself. Z1 Enterprises sells them.
Last edit: 04 Mar 2015 05:50 by Nessism.
  • martin_csr
  • martin_csr's Avatar
04 Mar 2015 06:02 - 04 Mar 2015 06:05
#663421
You can probably use the igniter from a late model police bike. The CSR's ignition system seems to be very similar & the timing advancer is the same as the 2005 P24 et al. just a possible option.
Last edit: 04 Mar 2015 06:05 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Mar 2015 06:50
#663428
I'd go with the Dyna S. $130
  • martin_csr
04 Mar 2015 07:03
#663434
If he needs the green Dyna coils, it would be another $130.
  • loudhvx
  • loudhvx's Avatar
04 Mar 2015 08:04
#663444
Nessism wrote: Ignitors are readily available on ebay. Of course the 1000 version are about double the cost of the 750 model, and likely near identical, but that's another matter. Converting to something more modern, like a Dyna S, is also an option. It will work fine with your stock coils so all you need is the unit itself. Z1 Enterprises sells them.
He would have to buy new coils to use a Dyna S (which would be a slight downgrade). It has a 3-ohm lower limit on coil resistance. His stock coils would be 2.3 ohm, originally.
  • lucienmaier
11 Mar 2015 14:38
#664116
So I also have a MSD mC1
Attachment IMG_16051.jpg not found
But I called them And there is no way to hook it up without the IC iignitor
I want to keep the stock coils so should I jsut get another IC ignitor, and Add the MSd down the road,
or go for the dnya s?
Anyone trade the MSD for a Dyna S?
  • MFolks
  • MFolks's Avatar
11 Mar 2015 17:09
#664131
Find the information on this website, about making your own IC Igniter replacement, using off the shelf GM electronic ignition modules. This only works on bikes with the mechanical ignition advancer(yours has one). "Loudhvx" is the person who's used one of these for many years.
A suitable subtitute for the Kawasaki IC Igniter(A pricey item)
This will only work for bikes having the mechanical ignition advancer:
The man who came up with the idea(Loudhvx at www.kzrider.com ) has used this for many years on his GPz 550.
GM HEI Ignition Modules (4 Pin) Cross Index
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
To build this replacement, you'll need two of the modules,colored wires,Aluminum mount plate(that will also be a heatsink) wire terminals,Diodes,Resistors, terminal mounting places for the components,wire strippers,and crimping tools for the terminals. I believe 18 gauge wire will work for this project, but 16 gauge will be better if higher current draw is expected. A soldering iron will be needed to solder the diodes and resistors in the circuits.
Wire Termination Insulation & Sizes
Terminal Insulation Color Wire Sizes
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
The ring terminal holes comes in many sizes, from #4 up to 1/2" in most cases, it's a matter of finding the tightest fitting hole to fit the fastener for the termination.
American Wire Gauge(AWG) is backwards to what many people think; that is 22 gauge is many times smaller than 10 gauge even though the number is bigger.
  • Tyrell Corp
  • Tyrell Corp's Avatar
11 Mar 2015 21:20 - 11 Mar 2015 21:24
#664146
Are you sure the brain is stuffed, not just dodgy wiring?
Heatshrink or soldered new wire tails to OEM Hitachi miniblock connectors would solve the wiring issue.
The factory Ic ignitors are pretty good, I'd google the part number and there are probably quite a few different kz / gpz / ltd bikes that you could find a used part from. Even 30 plus years old and they still seem to work ok. Dyna works good too on mine.
Last edit: 11 Mar 2015 21:24 by Tyrell Corp.
  • martin_csr
12 Mar 2015 06:03 - 12 Mar 2015 06:42
#664165
lucienmaier wrote: .....
I want to keep the stock coils so should I just get another IC ignitor, ....
The original stock coils are the weak link in the Kawasaki electronic ignition as they do most of the hard work & they are now 30+ yrs old. Some say they weren't that great to begin with ---- not sure if that's true, but I'm pretty sure the Dyna coils produce a better spark.
I acquired the stuff to make the HEI unit but haven't put it together yet. :blush:
Last edit: 12 Mar 2015 06:42 by martin_csr.
