I have a bad IC igniter what are my options?
- lucienmaier
03 Mar 2015 18:59
I have an 81 kz1000m csr that has a bad IG igniter.
What are the options for replacing this?
Attachment 11034267_10155191003520332_3909318796145121793_n.jpg not found
--1981 Kz1000m CSR--
--Converted to 1100CC---
- lucienmaier
Re: I have a bad IC igniter what are my options?
03 Mar 2015 19:00
I found this? Would it be a better option than stock off ebay?
www.z1enterprises.com/ItemDetails.aspx?i...dule%29&item=DYDBR-2
- loudhvx
03 Mar 2015 22:40 - 03 Mar 2015 22:44
That booster is for use with points.
You can make an igniter for about $40. I've been using this one for over 10 years:
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
Are you sure everything else is functioning?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 03 Mar 2015 22:44 by loudhvx.
04 Mar 2015 05:49 - 04 Mar 2015 05:50
Ignitors are readily available on ebay. Of course the 1000 version are about double the cost of the 750 model, and likely near identical, but that's another matter. Converting to something more modern, like a Dyna S, is also an option. It will work fine with your stock coils so all you need is the unit itself. Z1 Enterprises sells them.
Last edit: 04 Mar 2015 05:50 by Nessism.
04 Mar 2015 06:02 - 04 Mar 2015 06:05
You can probably use the igniter from a late model police bike. The CSR's ignition system seems to be very similar & the timing advancer is the same as the 2005 P24 et al. just a possible option.
Last edit: 04 Mar 2015 06:05 by martin_csr.
04 Mar 2015 06:50
I'd go with the Dyna S. $130
04 Mar 2015 07:03
If he needs the green Dyna coils, it would be another $130.
- loudhvx
04 Mar 2015 08:04He would have to buy new coils to use a Dyna S (which would be a slight downgrade). It has a 3-ohm lower limit on coil resistance. His stock coils would be 2.3 ohm, originally.Nessism wrote: Ignitors are readily available on ebay. Of course the 1000 version are about double the cost of the 750 model, and likely near identical, but that's another matter. Converting to something more modern, like a Dyna S, is also an option. It will work fine with your stock coils so all you need is the unit itself. Z1 Enterprises sells them.
1981 KZ550 D1 gpz.
Other links.
Other links.
- lucienmaier
11 Mar 2015 14:38
So I also have a MSD mC1
But I called them And there is no way to hook it up without the IC iignitor
I want to keep the stock coils so should I jsut get another IC ignitor, and Add the MSd down the road,
or go for the dnya s?
Anyone trade the MSD for a Dyna S?
Attachment IMG_16051.jpg not found
- MFolks
11 Mar 2015 17:09
Find the information on this website, about making your own IC Igniter replacement, using off the shelf GM electronic ignition modules. This only works on bikes with the mechanical ignition advancer(yours has one). "Loudhvx" is the person who's used one of these for many years.
A suitable subtitute for the Kawasaki IC Igniter(A pricey item)
This will only work for bikes having the mechanical ignition advancer:
The man who came up with the idea(Loudhvx at www.kzrider.com ) has used this for many years on his GPz 550.
GM HEI Ignition Modules (4 Pin) Cross Index
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
To build this replacement, you'll need two of the modules,colored wires,Aluminum mount plate(that will also be a heatsink) wire terminals,Diodes,Resistors, terminal mounting places for the components,wire strippers,and crimping tools for the terminals. I believe 18 gauge wire will work for this project, but 16 gauge will be better if higher current draw is expected. A soldering iron will be needed to solder the diodes and resistors in the circuits.
Wire Termination Insulation & Sizes
Terminal Insulation Color Wire Sizes
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
The ring terminal holes comes in many sizes, from #4 up to 1/2" in most cases, it's a matter of finding the tightest fitting hole to fit the fastener for the termination.
American Wire Gauge(AWG) is backwards to what many people think; that is 22 gauge is many times smaller than 10 gauge even though the number is bigger.
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
- Tyrell Corp
11 Mar 2015 21:20 - 11 Mar 2015 21:24
Are you sure the brain is stuffed, not just dodgy wiring?
Heatshrink or soldered new wire tails to OEM Hitachi miniblock connectors would solve the wiring issue.
The factory Ic ignitors are pretty good, I'd google the part number and there are probably quite a few different kz / gpz / ltd bikes that you could find a used part from. Even 30 plus years old and they still seem to work ok. Dyna works good too on mine.
Last edit: 11 Mar 2015 21:24 by Tyrell Corp.
12 Mar 2015 06:03 - 12 Mar 2015 06:42The original stock coils are the weak link in the Kawasaki electronic ignition as they do most of the hard work & they are now 30+ yrs old. Some say they weren't that great to begin with ---- not sure if that's true, but I'm pretty sure the Dyna coils produce a better spark.lucienmaier wrote: .....
I want to keep the stock coils so should I just get another IC ignitor, ....
I acquired the stuff to make the HEI unit but haven't put it together yet. :blush:
Last edit: 12 Mar 2015 06:42 by martin_csr.
