- Thank you received: 3
Ignition Issues
- element303
her is the reason why im writing and looking for some ideas. i rebuilt a 1981 kz750 4cyl and the bike always had issues, especially when warm or hot running very bad including backfire etc. i checked the carbs a million times and i can rule that out. they aren't perfect but clean and running. so i expected it to be the coils because the problems got worst and worst by day until last week it wouldn't even run anymore. it would run but you could here there was almost no detonation and once in a while it would detonate a cylinder running extremely rough. so i just installed the new coils and it turned on right away but as soon i drive it it just runs like crap. its stumbling trying to run but then you can feel and hear it have no right ignition or no correct detonation. almost like running out of fuel or having no spark or low spark. since its not the coils, what else could it be? it runs ok in idle, not great but it stays running. how about the igniter? i mean there isn't much else it could be besides bad cable right?
- pete greek1
- Thank you received: 185
Pete
- element303
- MFolks
- Thank you received: 540
- element303
- element303
- kaw-a-holic
- Thank you received: 249
I posted the Dyna S testing and installation in the file base. Make sure you disassemble, clean and lube the advancing mechanism behind that plate. I use heavy duty silicone spray because it goes on wet dries and does not collect dirt.element303 wrote: how can i adjust the timing here? i cant seem to see any markings on the plate outside.
If you have a manual I would suggest running through ALL of the routine maintenance.
Good luck
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- element303
- MFolks
- element303
- element303
- slayer61
- KZR FLAG RELAY CARRIER #62
element303 wrote: i just got it open, and it seems pretty much clean and the parts are moving too. its not stuck. does this look like ok condition? also, the lose cable in the bottom, is that ground and where is that supposed to go?
Cleanliness is next to Godliness! :lol: seriously, it could use a good cleaning and lubrication. This is where your ignition timing takes place and any troubles will show up as rough running.
The lose/un terminated wire looks like an oil pressure sensor. I would bet your oil light never comes on at all, unless the wire is accidentally or inadvertently grounded.
Just my guess! Good luck, Paul
