Disassembling speedo, changing faceplate, KZ 1000
  • ZERO
  • ZERO's Avatar
Re: Disassembling speedo, changing faceplate, KZ 1000
06 Jan 2014 02:09 - 06 Jan 2014 02:11
#617505
Once you make the slit, the ring will want to come off almost by itself. It's easy not to bend it. The hardest part is in finding a large enough hose clamp that the speedo will fit inside.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
Last edit: 06 Jan 2014 02:11 by ZERO.
  • martin_csr
  • martin_csr's Avatar
06 Jan 2014 06:20 - 06 Jan 2014 06:21
#617515
Not sure if it was mentioned yet in this topic, but the following link shows an alternate way to disassembled the meters. The method does cause some marrring, but the chrome meter covers I linked previously could be used on some models to hide the flaws (mostly 70s models).
WGCarbs - wiredgeorge - Gauge Glass Cleanup
Note: the article includes a link for re-calibrating a BMW speedometer.
Last edit: 06 Jan 2014 06:21 by martin_csr.
  • anotherZ
  • anotherZ's Avatar Topic Author
06 Jan 2014 06:56
#617518
I did my tach the way described in wiredgeaorge's post, but I didn't do as good of a job crimping the ring back together. I found it pretty difficult. I have it back together but it looks very crappy. Of course the chrome rings you suggested would be a solution!
When I did the speedo, I cut the ring and that worked better for me, however may due to my lack of "crimping patience" :-)
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
  • martin_csr
06 Jan 2014 07:14 - 06 Jan 2014 07:15
#617521
Something that might help in minimizing some of the scratching when re-installing the ring would be to use a protective plastic ring cut out from a plastic milk jug. At the least it may cut down on the top side marring. It might be slippy-slidy, though. I used milk jug plastic as rim protectors the 1st time I changed a tire - the plastic is tough & it worked.
Last edit: 06 Jan 2014 07:15 by martin_csr.
