Disassembling speedo, changing faceplate, KZ 1000
  • anotherZ
  • anotherZ's Avatar Topic Author
Re: Disassembling speedo, changing faceplate, KZ 1000
18 Dec 2013 15:30
#615850
Yeah I am sure that would be the best thing to do, but don't want to spend the money at this time of the year...
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
  • anotherZ
22 Dec 2013 17:10
#616177
Wow those spoons did the trick! Took me two minutes to pry the needle off without damaging it. Then it took me 30 minutes to find it, because it flew through my garage :laugh:
I had the hardest time to get the ring back on there that holds it all together. Doesn't look too good but it works. If I ever do a museum restoration, I will definitely have some specialists take care of them.
79 KZ 1000 LTD
Smaller tank
  • martin_csr
  • martin_csr's Avatar
23 Dec 2013 07:21 - 06 Jan 2014 09:24
#616205
Z1Enterprises.com sells replacement gauge cover clamps that fit some of the early KZs.
Z1Ent - Gauge Covers Chrome Top (pair) Kawasaki EM58-12410
Edit: these are decorative covers & I don't think they are intended to replace the clamping ring.
Last edit: 06 Jan 2014 09:24 by martin_csr.
  • anotherZ
23 Dec 2013 07:25
#616206
Yes I saw those, but if I am not mistaken, these clamps just hold the top chrome cover and the bottom bucket together, I don't believe they can function as a replacement for the crimped-on rings that ensure the water tight seal of gauge glass and body. But maybe I am wrong???
79 KZ 1000 LTD
Smaller tank
  • martin_csr
23 Dec 2013 07:53
#616211
I don't know, but you are probably right.
  • ZERO
  • ZERO's Avatar
02 Jan 2014 02:19
#617034
What I've always done is to cut through the ring with a cutting disc at the very bottom of the gauge and pull it off. After repair of the instrument, I put some black R.T.V. along the inside of the ring, re install it and then cover it with a hose clamp and tighten the clamp. Let it sit overnight. Removed the calmp and cleaned up with some laquer thinner. There is no visible damage to the clamp except for the tiny slit at the bottom, wich is now covered.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
  • anotherZ
02 Jan 2014 07:14
#617052
That seems to be a better idea compared to what I ended up doing. Cut the ring as you did and spot welded it back onto the speedo housing. I know, not pretty but works....
79 KZ 1000 LTD
Smaller tank
  • mdouglas71
  • mdouglas71's Avatar
03 Jan 2014 09:23
#617202
Wow, who woulda thought the spoons would work. :p
  • anotherZ
03 Jan 2014 12:23
#617220
They did, but next time I'll have a spotter with my so it won't take me 30 minutes to find the needle in the other corner of the garage ;)
79 KZ 1000 LTD
Smaller tank
  • Harvey1327
  • Harvey1327's Avatar
03 Jan 2014 15:16
#617234
A bit late now but I used a screwdriver to release the ring and to replace it I had 2 pieces of alu. tube which I got from motorcycle exhaust shop that are close to the same size as the ring and taped the edges of the tubes and
slowly tapped down until I was :woohoo:
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
03 Jan 2014 21:19 - 03 Jan 2014 21:20
#617251
No eBay APP ID and/or Cert ID defined in Kunena configurationIt looks like someone has started making reproduction clamp rings for these gauges.
The eBay auction was:
ebay.com/itm?itemId=291049791377
The seller is retro-motorcycles. But my guess is they are made by one of the Japanese reproduction folks (e.g. Doremi).
My dad's '74 Z1
'00 ZRX1100
Last edit: 03 Jan 2014 21:20 by DOHC.
  • KZB2 650
  • KZB2 650's Avatar
04 Jan 2014 10:28
#617301
ZERO wrote: What I've always done is to cut through the ring with a cutting disc at the very bottom of the gauge and pull it off. After repair of the instrument, I put some black R.T.V. along the inside of the ring, re install it and then cover it with a hose clamp and tighten the clamp. Let it sit overnight. Removed the calmp and cleaned up with some laquer thinner. There is no visible damage to the clamp except for the tiny slit at the bottom, wich is now covered.
Been thinking of doing this (for my KZ650) just to wipe out the water spotting ....... but Was thinking you would need to cut it in two places but you can do it on the bottom only and get it off without springing it outta shape ???
This is defently on my list to do if so. Thanks.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
