any LED headlight replacements suggestions!?
- jbalet666
Re: any LED headlight replacements suggestions!?
04 Jun 2013 00:49martin_csr wrote: The 750-4 lens unit swap was easy & cheap, and an Emgo replacement bulb is less than $4. I'm still using the bulb that came w the headlight, but I got an Emgo from Z1 as a spare. ... not sure an auto parts store will have the H4 bulb. I guess a halogen sealed beam would be easier, though.
yeah im thinking about just getting a sealed one but in the long run it seems more "economical" to buy an unsealed unit and bulb
if i get the H4 its just plug and play right?
or will i need all the other tid bits the other guys were talking about?
81 650csr
AoA
old soul young blood
AoA
- schuss
04 Jun 2013 11:32Rainman wrote: I have run the previous version of the Truck-lite 7" LED headlight for several years on a 80 KZ750-H1 and it works great, lots of light at night.
Flickers a little at idle but has not been a problem. Unique low beam.
Good luck,
Jim
Jim - how did you work out mounting it? Newer model housing like other folks have suggested, or did it fit without modification?
- schuss
04 Jun 2013 11:32
I've been looking at HID -the light from them is pretty incredible, have always used them on my street bikes.
www.xenonrider.com/products/h4_bixenon_hid_kits.shtml
The bi-xenon ones are a single bulb that uses a magnetic reflector angle adjustment to switch from hi to low beam, so there's no warm up time between. Half the cost of LED, but you have to find a place for the ballasts.
That LED looks so efficient, though! (1.8a low beam, 3.8a high beam!!) That's so tempting. Looks nice, too.
04 Jun 2013 15:14 - 04 Jun 2013 18:37Down the road, the H4 is probably cheaper. Easier too. Changing the bulb is a simple matter, whereas changing the sealed beam each time is more work. The Wagner part might be the safest choice, but they all have a 60W high beam - just keep in mind that the bike is 30+ yrs old & so is the wiring. The headlight has its own fuse, so you've got some protection there. Since stock is a 60W/50W sealed beam, the halogen part from Z1 you linked would be the closest match to stock. But I've gone several thousand miles w the 60W/55W H4 750 stuff. The 650-CSR is very similar to the 750-4s & I bet the wiring is about the same.jbalet666 wrote: yeah im thinking about just getting a sealed one but in the long run it seems more "economical" to buy an unsealed unit and bulb
And the 750 H4 stuff is plug n play... very easy.
Last edit: 04 Jun 2013 18:37 by martin_csr.
