gas tank low sensor
  • martin_csr
  • martin_csr's Avatar
Re: ---->>>> Low fuel switch photo photosz
26 Oct 2012 16:08 - 22 Feb 2013 10:05
#555893
wireman wrote: Can you post a picture from the top side so I can see how its attached to the plate? B)
This is the best I've got, which shouldn't matter, since all you can see from the top is that black insulator.
The underside where the wire is attached has a red plastic fitting w a wire connector kinda riveted thru the center of it. Pattons's ebbaayy link has a fairly decent photo of the red fitting.
Last edit: 22 Feb 2013 10:05 by martin_csr.
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
Re: gas tank low sensor
05 Nov 2012 17:24
#557148
i think it was the iso-heet, that is the last time i talk to them about gas tank rust. now my fuel petcock is leaking. i turned it to pri and it started guzzling out in between the vacuum thing and the petcock. iso heeet gets a bad review from me.
  • donthaveakawman
05 Nov 2012 21:47
#557167
I think it has been leaking for a while into the vacuum hose, that would explain the occasional sputter when i restart it. Today at a gas station in +#^!^0I fouled it out(gas on plug(s) , so i had to rev it up to blow some of the gas out of the engine, and the dumb-ass pulling out behind me in the pickup thought it was a good reason for a one man tire burning competition.
The vacuum hose that is on there is clear so i can also see it light up when it is being warmed up with the choke on. now it is spewing all over the place.
I also lost the bolt and washer for the gas tank, how stupid, I drilled out the bottom of the air box under the filter(before if it came loose it would just fall in the filter).
  • martin_csr
06 Nov 2012 13:03 - 23 Jan 2013 11:50
#557242
Where did you drill the holes in the airbox? ... I'm wondering about unfiltered air?
Z1Enterprises.com sells petcock kits. I just got the diaphragm kit this time... it's a little cheaper than the rebuild kit. Mine was spewing fuel out the edge of the diaphragm cover. The Kaw dealer may have the stuff.
Last edit: 23 Jan 2013 11:50 by martin_csr.
  • donthaveakawman
06 Nov 2012 15:55
#557271
I will post a picture later of the airbox, i am going to talk to the kawasaki dealer later to see if they have got one, otherwise it is 7.24 for shipping from z1 and from new york to washington.
  • donthaveakawman
06 Nov 2012 16:23
#557275
Attachment 6001.jpg not found
Attachment 6002.jpg not found
I took those pictures asbestos I could, when I drilled the air box I did it alabama self.
  • donthaveakawman
06 Nov 2012 16:27
#557280
Hey these pictures are really helping, i already found my tackle box.
  • donthaveakawman
08 Nov 2012 01:47
#557471
I was very happy with that Shinko tire so i got a different Shinko tire. something about Shinko. It seems that motorcycle tires is about all they do.
  • donthaveakawman
08 Nov 2012 03:29
#557479
yeah i am thinking cold air is next.
  • donthaveakawman
13 Nov 2012 03:58
#558166
dammit it's leaking again. I put zip ties on the airbox boots and found out my jb weld just wan's good enough.
  • martin_csr
Re: Low fuel switch photo photosz
13 Nov 2012 09:53 - 22 Feb 2013 10:08
#558178
Z1Enterprises.com has the airbox ducts.
For a patch job, something more flexible than jbweld is probably needed,
but I would go ahead & get new ducts.
Last edit: 22 Feb 2013 10:08 by martin_csr.
  • donthaveakawman
13 Nov 2012 19:01
#558239
air ducts are OK, a little worse for the wear. just when rubber/plastic gets soaked with gas it stretches i guess. runs a lot smoother with those tight on there.
The fuel gauge switch is leaky so i ordered a new gasket today(a week i guess), and last night i soldered around the inside part and now the gasket is made of really small fuel hose that i used to replace the gasket by wrapping it around the indent. still leaks but not so much i will have to wait for the gasket. :side:
