gas tank low sensor 23 Oct 2012 02:47 #555331
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
  • Visitor
I am leaking gas like a chili bean sampler with a loose sphincter. the fuel light sending unit is leaking right at the wires. i took it off and cleaned it then reinstalled it with some gas resistant gasket sealer. i am pretty sure now that it is leaking through the wires....drip drip drip. now as the gas is draining again i am pretty sure i will have to slab some goo on the wires and keep my eyes open for a replacement.
gas tank low sensor 23 Oct 2012 04:09 #555333
  • donthaveakawman
  • Visitor
donthaveakawman wrote: I am leaking gas like a chili bean sampler with a loose sphincter. the fuel light sending unit is leaking right at the wires. i took it off and cleaned it then reinstalled it with some gas resistant gasket sealer. i am pretty sure now that it is leaking through the wires....drip drip drip. now as the gas is draining again i am pretty sure i will have to slab some goo on the wires and keep my eyes open for a replacement.
sorry to have said sphincter and loose in the same post. it is vulgar, i am in a bad mood and have 89 test octane smell in my hair.
Seal-All Low fuel switch 23 Oct 2012 09:09 #555334
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
It's a common problem & your fix typical. I used Permatex liquid metal. My pigtail had broken off, so I repaired that as well, making it longer so that my hand wouldn't contact it when fiddling w the idle adjust thumbscrew. Also, I replaced the o-ring w one from a HF metric kit.
Edit: z1kzonly ---->>>> Seal-All It is in a yellow tube $2.79. It looks like model glue.
Been around for 30 years. seals gas!
Last edit: by martin_csr.
gas tank low sensor 23 Oct 2012 19:41 #555431
  • donthaveakawman
  • Visitor
furthermore the metal lamp i was using had a bent part connecting to the light bulb where it screws in. when i hung it on the kickstand and touched the engine while laying on the ground(no centerstand, just had it balanced on cinder blocks)... well i had fun with electricity while working with gas.
gas tank low sensor 23 Oct 2012 20:45 #555446
  • wireman
  • wireman's Avatar
  • Thank you received: 299
Can you post a picture of the leak? B)
gas tank low sensor 23 Oct 2012 21:08 #555453
  • donthaveakawman
  • Visitor
mental picture is as follows: gulf oil spill with electric eels going crazy
---->>>> Low fuel switch photo photosz 24 Oct 2012 13:15 #555565
  • martin_csr
wireman wrote: Can you post a picture of the leak? B)
The yellow wire (blue arrows) is insulated from the base plate.
The connection is press fit or something. Over time, it becomes loose & leaks.
I'm assuming he has the same fuel level switch.
Low fuel switch photo photosz zphotoz
gas tank low sensor 25 Oct 2012 22:48 #555787
  • donthaveakawman
  • Visitor
right out of the red thing.... i installed some jb weld and it seems to be working fine. i tried looking for a new one on ebay and i couldn't figure out what to call it.
gas tank low sensor 26 Oct 2012 11:28 #555858
  • Thank you received: 2098
donthaveakawman wrote: ...tried looking for a new one on ebay and i couldn't figure out what to call it.
The parts diagrams at kawasaki.com usually show both the name and part number.
If needed, there's a link in my sig for help with navigating.
An ebay search using only the part number often produces results.
Good Fortune! :)
---->>>> Low fuel switch photo photosz 26 Oct 2012 11:53 #555862
  • martin_csr
A nos fuel level switch would be good, but they're usually priced kinda high nowadays.
Used will be listed in several ways: fuel sender, fuel sensor, gas sensor, gas gauge, fuel gage, low fuel switch, etc.
gas tank low sensor 26 Oct 2012 12:11 #555865
  • wireman
  • wireman's Avatar
Can you post a picture from the top side so I can see how its attached to the plate? B)
gas tank low sensor 26 Oct 2012 12:34 #555867
No eBay APP ID and/or Cert ID defined in Kunena configurationPer kawasaki.com, the same FUEL LEVEL SWITCH, part number 27010-1055, is shared on the following 14 models:
KZ1000-M2 (CSR) (1982)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-F1 (LTD Shaft) (1983)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
KZ750-N1 (Spectre) (1982)
KZ750-N2 (Spectre) (1983)
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Good Fortune! :)
Last edit: by Patton.
