The bike won't start
  • marcus91
  • marcus91's Avatar Topic Author
02 Oct 2012 13:19 - 03 Oct 2012 04:24
#552000
When I bought my bike for a week ago it came with pod-filters. The engine backfired a lot (but when I ran with choke it was a lot less backfiring) and lacked som power. So yesterday I bought a original air box thinking that this would solve the problem, but it only made it worse. After the installation of the original air box, the bike won't start. All I can hear now is just "clunc clunc clunc poff poff clunc clunc POOP!!" (Clunc being the starter, poff being som weird small sound and POOP being a very loud backfire).
Ive checked #1 and #4 spark plugs, which was fouled (most likely from yesterday when I rode around with the pod-filters and choke). So Im thinking it must either be the spark plugs or valve-adjustment. Can someone verify this? Is valve-adjustment a mechanics job? If someone will be kind enough to make a video on how to adjust the valves I would actually PAY THEM!
1981 Kawasaki Z650SR
Last edit: 03 Oct 2012 04:24 by marcus91. Reason: New problem!
Re: Where does this electrical plate sit?
02 Oct 2012 13:31
#552004
Does it go on the firewall of a 1979 Chevy Caprice? :whistle: Ed
  • trianglelaguna
  • trianglelaguna's Avatar
02 Oct 2012 13:34
#552005
under the dishwasher
maytag model 3456yhs0929 1999-2003 white or bone color
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • marcus91
02 Oct 2012 13:39
#552007
So basically it is not original for Z650SR?!?
  • trianglelaguna
02 Oct 2012 13:45
#552011
oh thats different you have a motorcycle...never knew
look in the manual
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
02 Oct 2012 13:47
#552012
it goes either under the seat or in a side cover..most likely side cover..the silver bulbs are tyrn signal flashers and the fuses..well there fuses..
post the year and model and someone here will know
1976 KZ900
2003 ZX12R
2007 FZ1000
02 Oct 2012 13:48
#552013
No, it is not from a Z650.
  • marcus91
02 Oct 2012 18:00
#552043
Alright.. New problem with the bike! :(
The bike had POD-filters when I bought it. It backfired and only ran with choke. So today I bought a new standard airbox, which I replaced with the POD-filters. Now the bike wont start, and only backfires.. Poff-Poff-POOP!! (POOP being a HUGE backfire sounding like someone shot a rifle inside).
I would think that it gets both fuel and spark since it backfires? Any suggestions to what I can check?
  • boyd825
  • boyd825's Avatar
  • Ride it like you stole it!
02 Oct 2012 18:07
#552045
Take another bad picture of the problem so we can properly diagnose it. :laugh:
1977 KZ1000 A1
  • marcus91
02 Oct 2012 18:11 - 02 Oct 2012 18:11
#552046
Found a solution to that problem problem.. No more worries about that matter. Need some help on the other problem though.
Last edit: 02 Oct 2012 18:11 by marcus91.
  • BRABBIT04161991
  • BRABBIT04161991's Avatar
02 Oct 2012 18:27
#552047
Sounds like your jetting in the carbs. I'd tear your carbs down and clean em up real good and check the sizes of the jets in them. If they were running pod filters before the previous owner may have put bigger jets in them to account for the more air coming in. Anther thing to check if you haven't already done it, make sure you're vacuum lines are hooked up correctly on the carbs. Do you still have the pod filters??
02 Oct 2012 18:28
#552048
When you installed the airbox did you install a filter inside it? Ed
