Electronic ignition questions
- gumby prichard
Re: Electronic ignition questions
18 Sep 2012 18:55
i know, i know. i cant complain about emgo coils, but i figure, performance ignition....may as well get performance coil. if i dont win one on ebay this week i will just settle with emgo.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
03 Oct 2012 18:56
got a dual output dyna coil off ebay, ended up being blown. no resistance in the contacts
my luck. well dude immediatly refunded me and i just went to my local NOS :laugh: dealer friend and bought a used oem 4ohm coil with replacible contacts and wires. it's running pretty good, very strong spark.
It's still backfiring some, may be carb issues, but i still want to fine tune the ignition, but need to know where to drill the holes!
anyone know the proper positioning for the dyna s electronic ignition?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- loudhvx
04 Oct 2012 13:21
A timing light will show you where the ignition is firing at. From there you can tell which way to rotate the plate. If it's running pretty good, I don't think you will need new holes, but just elongate the ones you are using now. I think the pickups on the Dyna S might have a tiny bit of adjustment in them as well, but I might be thinking of the Dyna III.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
