Electronic ignition questions
Re: Electronic ignition questions
13 Sep 2012 16:49
#548488
Would not use a coil having less than 3 ohms resistance with a Dyna-S ignition.
Stock coils on models with Kawasaki electronic ignition are often less than 3 ohms.
Good Fortune! :)
The following user(s) said Thank You: gumby prichard
  • gumby prichard
  • gumby prichard's Avatar Topic Author
13 Sep 2012 17:41
#548495
thank you patton! that's what i was looking for
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • Del_Herring
  • Del_Herring's Avatar
14 Sep 2012 11:01
#548617
Going too low on ohms will allow higher current which can damage things (like the Dyna S says to use no lower than 3 ohm), if you go too high you can end up with a weak spark due to having too much resistance in the circuit, but it's not necessarily going to outright break anything. I think the stock Kawasaki's are 2 ohms on a lot of models, so with the stck system you'd probably be fine there.
I figure if replacing, go with 3's, just because you'll be fine with either the stock or dyna s system down the road.
1983 KZ750-N2 Spectre
  • loudhvx
  • loudhvx's Avatar
14 Sep 2012 16:15
#548666
As Del and Patton said, you don't want to go lower than 3 ohms on the Dyna S.
Most of the factory electronic ignition systems used 2.3 ohm (but usually measure higher, like 2.5 to 2.7).
The factory points coils, which is what your bike would have come with, had 4 ohms.
  • gumby prichard
15 Sep 2012 14:50 - 15 Sep 2012 15:45
#548870
so this could cause a problem with my electrical system correct? i mean if i have a point system and im using 2ohm coils when i should have 4ohm coil, which would allow a higher current, could burn up something? correct? causing my bike to not run right?
my charging system seems week i really hope the regulator rectifier isnt burnt. :sick: :(
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 15 Sep 2012 15:45 by gumby prichard.
  • gumby prichard
15 Sep 2012 15:39 - 15 Sep 2012 15:41
#548876
this sounds contradicting. im confused, wait ok so you're saying the coils i have currently, the (4cyl) coils are most likely 2 ohms, but my stock kz750 twin coils(if i had them) would be 4ohms? correct?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 15 Sep 2012 15:41 by gumby prichard.
  • MFolks
  • MFolks's Avatar
15 Sep 2012 15:51
#548878
Here's how to troubleshoot the charging system:
www.electrosport.com/technical-resources.../fault-finding-guide
  • bountyhunter
  • bountyhunter's Avatar
15 Sep 2012 16:51
#548886
gumby prichard wrote: so this could cause a problem with my electrical system correct? i mean if i have a point system and im using 2ohm coils when i should have 4ohm coil, which would allow a higher current, could burn up something? correct?
YES. You will fry the coil and maybe some wiring.
  • bountyhunter
15 Sep 2012 16:52
#548888
gumby prichard wrote: this sounds contradicting. im confused, wait ok so you're saying the coils i have currently, the (4cyl) coils are most likely 2 ohms, but my stock kz750 twin coils(if i had them) would be 4ohms? correct?
Yes, the stock 750 twin with points used a 4 Ohm coil which would work fine with your Dyna ignition.
  • gumby prichard
15 Sep 2012 17:59
#548894
thank you guys, this would probably explain why the condensor that was in it that looked brand new was not working..... you guys have been much help. I will try to find a higher resistance coil until i find a fair price on a dyna 3 ohm.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • MFolks
  • MFolks's Avatar
15 Sep 2012 18:44
#548901
I doubt you can beat www.z1enterprises.com for Dyna coil costs.
  • bountyhunter
15 Sep 2012 21:27 - 15 Sep 2012 21:30
#548940
gumby prichard wrote: thank you guys, this would probably explain why the condensor that was in it that looked brand new was not working..... you guys have been much help. I will try to find a higher resistance coil until i find a fair price on a dyna 3 ohm.
Z1 sells four Ohm EMGO coils with wires for $36 each.
I've been running one for 6 years and it works great.
Last edit: 15 Sep 2012 21:30 by bountyhunter.
