kz1000 no power
  • 78craft
  • 78craft's Avatar Topic Author
kz1000 no power
21 Aug 2012 12:01
#543862
I recently was given a 1980 kz1000 ltd from my uncle. Bike has run great for the past month, put about 1000 miles on it in the past few weeks.
Last night I got caught in a rain storm. Bike died and was tough to restart. Got it restarted and it died again. This time I noticed that my "push start button" was broken. It was taped previously apparently and I never noticed it. Now im in the middle of a highway and pushed the bike off to a gas station. At this point i still had my lights.
Got to the gas station to try to get the button in to just make it home(was only two miles from the house). I went into the gas station to grab a screw driver to get the spring alinged to get the button back in. When I did this I must have pushed the screwdriver in to far as I lost all power.
When i turn the ignition to on nothing happens no lights nothing.
My question is, what could this be? I have not been able to check fuses(happend last night and am working today). The bike has a aftermarket windjammer on it. Where would the fuses be located?
Also why would my bike have died in the rain and been tough to restart?
Lastly what part do I need to replace the "push start button" on the right handlebar.
This is my first bike so bare with me.
Thank you in advance for your help!
  • 78craft
Re: kz1000 no power
21 Aug 2012 12:04
#543864
Attachment bike.jpg not found
and I know everyone loves pictures so here she is.
  • peter1958
  • peter1958's Avatar
Re: kz1000 no power
21 Aug 2012 12:31
#543877
That's A real nice looking bike. The fuses should be under the left side cover. The switch might have gotten water in and shorted out.
  • 78craft
Re: kz1000 no power
21 Aug 2012 12:44
#543882
the ignition switch or the "starter button" on the right handle bar? My fingers are crossed that its a fuse as everything went dead once I got the screwdrive inside the right handle bar where the start button is. Wish i would have tried to kick start it
Also where can I find a right handle bar switch with the "on off on" and the start button?
  • 78craft
Re: kz1000 no power
21 Aug 2012 13:21
#543893
would this 5 prong work with my bike? He also has a 4 prong plug in that looks the exact same. My current switch does not have an on off for the lights?
  • MFolks
  • MFolks's Avatar
Re: kz1000 no power
21 Aug 2012 13:29
#543894
Some websites to find replacement handlebar switches(probably the entire assembly):
www.redlinecycle.com
www.americanclassix.com
www.reproductiondecals.com (they also sell parts)
www.kandstech.com/index.php?page=switchescontrols
  • pete greek1
  • pete greek1's Avatar
Re: kz1000 no power
21 Aug 2012 13:33
#543895
78craft, thats a used one from a 74 900, 6 years older than the one you had, for about the same price, you can get a new one from Z1 enterprize...Pete
  • 78craft
Re: kz1000 no power
21 Aug 2012 13:47
#543899
actually looks like this one would work.
  • 78craft
Re: kz1000 no power
21 Aug 2012 13:56
#543903
pete greek1 wrote: 78craft, thats a used one from a 74 900, 6 years older than the one you had, for about the same price, you can get a new one from Z1 enterprize...Pete
www.z1enterprises.com/ItemDetails.aspx?item=EM99-68892 this is all i could find on the site?
  • pete greek1
Re: kz1000 no power
21 Aug 2012 20:44
#543964
call Z1 up, I believe they have the one you need, I"m just not good at navigating their website :( ....Pete
  • 78craft
Re: kz1000 no power
21 Aug 2012 21:51
#543975
pete greek1 wrote: call Z1 up, I believe they have the one you need, I"m just not good at navigating their website :( ....Pete
Will do. There website is tough.
I ended up getting the bike going. 20 amp fuse was blown. Switched that and got power. Luckily my driveway is on a hill so i rode it down there to fire it up. Runs fine was a bit rough to start but smoothed out.
I can not figure out the start button even to just get it going with it. It has a spring and a button. Has anyone had one of these things apart? I cant figure out if I am missing a peice or if the thing is just shot.
  • 78craft
Re: kz1000 no power
22 Aug 2012 21:55
#544189
well tried to play with the switch portion tonight. Dont want to get to far in without having another one here. Odd thing today, i kicked started it, it fired right up ran for about 20 seconds then died. Wont re-fire kick starting or roll starting down my driveway hill.
hoping that it just fired off with the fuel in the carb and i did not have the choke open far enough and it just died.
