GPz550 No Spark
  • rcook52459
  • rcook52459's Avatar
Re: GPz550 No Spark
29 Jul 2012 19:57
#539442
i talked to u yesterday about an igniter i have on craigslist.is there anyway u can bring the bike to portland.maybe i can help u get started.we can hook up the igniter i have to see if that is the problem.have 2119-1020 igniter(for mechincal advance) think he needs a 2119-1055 igniter(electronic advance),but it will start the bike if that's the problem.
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
  • marsracer
  • marsracer's Avatar Topic Author
Re: GPz550 No Spark
29 Jul 2012 20:08
#539445
Does anyone know if there are any links or videos on youtube that I can watch someone do it. I don't know wiring diagrams. I'm sorry. I don't want to be a pain in the a$$. I'm just stuck between a rock and a hard place. I don't know electrical like I should if I am getting into something like this. I also need to figure out how to put the air box back on. I wanted to put 4 cone filters and a 4 to 1 exhaust on it. Then I found out there's more to it that bolting on these things. I didn't know you have to do carb work to keep up with it. That makes since to me tho. But when it comes to electrical, I am pretty much lost. I never used a multimeter before. That's why I'm having a hard time here. But please bear with me. I will get the hang of it sooner or later and know what I'm doing next time.
  • Motor Head
  • Motor Head's Avatar
Re: GPz550 No Spark
29 Jul 2012 20:17
#539447
Post up what meter you have, and we can tell you how to use it. But watch the video I posted, or check out some of the others on how to use a meter.
  • marsracer
Re: GPz550 No Spark
29 Jul 2012 21:13
#539466
Thank you Motor Head and Patton. I just got off the phone with rcook52459. I think if things went right, we narrowed it down to either my battery is too far gone to send 12v to the coils or the igniter is shot. I am going to get the GM parts and attempt to build the other type set up. Thank everybody for all their help.
  • MFolks
  • MFolks's Avatar
Re: GPz550 No Spark
29 Jul 2012 22:56
#539488
GM HEI Ignition Modules (4 Pin) Cross Index
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
  • marsracer
Re: GPz550 No Spark
31 Jul 2012 01:30
#539667
Well, I got her to spudder today. After 2 days on the battery charger I got some spark out of her. It has boiled down to just needing anew battery. Where do I find out what battery I need. My girl friend works at an auto part store and can get me a battery. I just don't know what cca or ca I need for it.
  • MFolks
  • MFolks's Avatar
Re: GPz550 No Spark
31 Jul 2012 01:58
#539670
Try this website, it should be able to tell you what battery you'll need:
Motorcycle Batteries
www.yuasabatteries.com/ (Wet Cell Battery)
Re: GPz550 No Spark
31 Jul 2012 07:46
#539685
  • rcook52459
Re: GPz550 No Spark
31 Jul 2012 13:13
#539743
get the one with the most cranking amps you can afford.batteries are pretty much made in the same factories and companies buy enough of them where they put they're labels or even make them the color they want.if your girlfriend can't get you one.got mine on sale at bi-mart or even try walmart.
  • marsracer
Re: GPz550 No Spark
31 Jul 2012 14:20
#539755
What's the part number of your battery? I will just go look for that one. I got it to spudder yesterday. But it didn't fully fire. I'm so close to getting her on the road.
  • marsracer
Re: GPz550 No Spark
31 Jul 2012 15:45
#539774
I have to thank every one on here for all their help. Bikes are not exactly like a car. I started getting some spark yesterday but was very weak. Then late in the afternoon it spuddered. Well today I got her to fire and run. I took her around the block twice. I feel a little too tall for the bike. It has some noise in the front end. Sounded like a small exhaust leak but when I checked there was more of a knock. I'm hoping it is more of an adjustment than something that so gone. Like a spun bearing or a bent valve or something.
  • marsracer
Re: GPz550 No Spark
13 Aug 2012 15:56
#542304
Okay. Here's a good question for you. I have spark on 1 cylinder only. The bike ran perfect for about 20 miles. Then after sitting for about an hour, I turned back and it ran like crap. You can feel and hear it when it fired on all 4. But then would loose a cylinder or 2. I was in town stuck in traffic and as I pulled in the clutch, it just died. So I've had it on the charger for a few days. I'm still only getting spark form only one spark plug wire. Is that most likely a battery or should I just part this thing out?
