- Thank you received: 1616
No thermoplastic switches. No nylon switches.
- loudhvx
Only use epoxy-resin, bakelight, or metal.
Epoxy-resin will usually come in black red green or blue, but will not have the shiny look like nylon or vinyl. They will have a duller, or dusty look to them.
These metal ones look good.
This nylon/plastic one below is not acceptable. It will melt.
Notice the grabbing tabs used for mounting. Epoxy-resin will never have them molded in like this. Only plastic (vinyl) or nylon will have those tabs.
This one has no rating, but it looks good for ignition and lights. You could probably wire it for ignition in one position, then ignition plus lights in the other position, or ignition plus low beam, and ignition plus high beam. But email to confirm it can handle 20A.
This type, below, is almost always epoxy-resin. Notice there are no cheasy mounting tabs... Good old, threaded, metal neck. There are also all-metal versions of this, but are usually made of pot-metal. The epoxy-resin version may actually be better, but either is acceptable. The drawback on these is they take a lot of space, and are not very sleek.
This type, below, is not acceptable. Notice it is entirely plastic. You can tell it's nylon or plastic because the case uses tabs to hold together.
End of rant, for now.
BTW Steve, these are all UK sellers or international sellers.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Thank you received: 797
"when it comes to switches,don't use small ones,cute ones or plastic ones!"
oh yeah that was lou :laugh: .
thanks for being so helpful to all of the electrichallenged of us on here.
you are a great resource and a strength of this forum.
- 750steve
531blackbanshee wrote: a smart man once told me:
I'll definately second that, this thread probaby came about as a result of me (probably) annoying Lou via PM for some switch advice. Im getting some switch housing's CNC'd so i want ones that aint a pile of poo & melt easily. Unfortunately i need small & would like cute! :lol:
Seriously though, i'd be lost & confused without Lou's advice!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- loudhvx
I haven't looked into it, but you may want to look into aircraft switches. They are probably the best thing out there. I just didn't happen to search them on ebay. They have momentary toggles that look like the standard on-off toggles, so at least the switches would match each other.
I guess, for cuteness, I like the looks of that second momentary metal button. I wounder if they have a push-button toggle version of it that matches in looks.
The ignition switch should be rated for 20A. The starter button, as we discussed, can probably get by with 3 or 4 amps.
1981 KZ550 D1 gpz.
Other links.
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
- 750steve
Anyway, i've been asking Lou what current certain switches needed to carry for different applications, i THINK thats what his post is based on. Try getting a GOOD but SMALL 20A switch for the kill/on switch & a good SMALL 10+ Amp (pref off/on/on or on/off/on) switch for the lights & you'll see too! :lol:
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- clutch
Wish List:
Z1 (need I...
- MFolks
- Thank you received: 540
MS24523-22 SPST Toggle Switch
www.alliedelec.com/search/productdetail.aspx?SKU=6422180
MS24523-23 SPDT Toggle Switch
www.bpbsurplus.com/lc/cart.php?target=pr...7468&category_id=325
MS24523-28 SPST Toggle Switch Momentary
www.bpbsurplus.com/lc/cart.php?target=pr...8139&category_id=325
MS24524-22 DPST Toggle Switch
www.prowireusa.com/prodinfo.asp?number=MS24524-22
MS24524-27 DPDT Toggle Switch Momentary
www.bpbsurplus.com/lc/cart.php?target=pr...8722&category_id=325
- 750steve
www.bpbsurplus.com/lc/cart.php?target=category&category_id=468
I'll look through those links. Better to get the correct switch now as further down the line it'll save some hassle & frustration.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- MFolks
They can't be beat for moisture and vibration resistance, many of the off roaders use them in their vehicles for reliabilty.
Some other websites for electrical related parts:
www.corsa-technic.com/index.php
www.prowireusa.com/
