KZ750 Twin, B2, Electronic Ignition Retrofit
- 750steve
02 Oct 2011 16:33 - 02 Oct 2011 16:43
This is a run on from another thread which was getting off subject so it was suggested i start a new thread. I didn't even knoe you could convert my bike to an electronic ignition. What are it's advantages besides less adjustment & wear on the points?, does it give a better spark & run better?
Motor Head very kindly pointed me in the direction of some relevant historical threads, the parts seem hard to find as mentioned in the threads, besides not knowing what im really looking for some of the items seem to be fetching a good price, so the link under this quote might be a better option.
I then came across this on the Twins Owners Forum & it seems quite good. I was wondering which would be the better setup?
www.armbell.com/forum/viewtopic.php?t=12...start=0&mforum=kz400
This also seems to have an electronic Tacho output, i'll be needing that too as im replacing my clocks.
Thank you for all your help so far guys.
Motor Head wrote: kzrider.com/forum/4-electrical/229999-electronic-conversion
kzrider.com/forum/4-electrical/232924-wh...on-for-76-kz750-twin
kzrider.com/forum/4-electrical/200137-19...-electronic-ignition
Here is some KZR threads for you to read.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 02 Oct 2011 16:43 by 750steve.
Re: KZ750 Twin, B2, Electronic Ignition Retrofit
02 Oct 2011 16:57
With a points system, every single time the points open there is a small arc of electricity that pits the contacts and subtly alters spark timing and begins to wear the contacts, the follower or rubbing block also wears with every single revolution. As the points age, the spring can begin to loose tension, increasing the possibility of point float at high rpm. The condenser also becomes slightly less efficient each time it discharges. Even in the most high quality points, there is a bit of slop even when new. Put this all together and you have a situation in which the spark timing and duration are a tiny bit unstable and constantly deteriorating. This assumes that they were set up perfectly to begin with.
The electronic ignition eliminates these weakneses and will provide consistent spark for many years and thousand of miles.
The strength of the spark is largely determined by the battery and coil(s), but is also affected by the secondary wiring and spark plugs.
The following user(s) said Thank You: 750steve
- 750steve
02 Oct 2011 17:04
Thank you, that was a big help in my 'should i convert' question in my head.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
02 Oct 2011 17:07
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationLets see if any of this stuff will help?
750 Twin Advancer can lobe, does it fit right on to your's, Steele?
cgi.ebay.com/ebaymotors/82-Kawasaki-KZ-7...&hash=item35b49893cc
Ignitior Box:
cgi.ebay.com/ebaymotors/Transistor-Ignit...&hash=item336ba8d3c4
Pick-up Pulse coil
cgi.ebay.com/ebaymotors/Kawasaki-1981-KZ...&hash=item25664bd603
Ignitior Box:
Pick-up Pulse coil
- 750steve
02 Oct 2011 17:29
Thanks Motor Head, seller of the 1st item only ships to USA though & the shipping of the next 2 items comes in at nearly $50, not that i mind to be honest, but you can see how when shipping is added it nearly comes to the price of the system on the twins forum.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
02 Oct 2011 17:34
Yes I gathered that, and I'm still looking. Posted it all for comment from the other members, maybe like that won't work, or hey I got one. Who knows. If you were to buy in pieces like that off of Feebay, have it shipped to a central person, then to you in one box. Someone you could trust to do it for you. If you did get to a point like that I could do it for you. I'm in Colorado, nearly dead center of the USA.
- 750steve
02 Oct 2011 17:59 - 02 Oct 2011 19:02
Now thats above & beyond the call of duty! Thank you v much for the offer!
Colorado, nice place (i hear), i'd love to visit there 1 day.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 02 Oct 2011 19:02 by 750steve. Reason: Spelling - Get used to it
- MFolks
02 Oct 2011 18:31
The city of Denver is called the "Mile High City" due to the elevation. When the USAF had Lowry AFB outside of Denver open, I went there during 1966 for a aircraft weapons mechanic school, and every weekend off, took trips up into the mountains. Beautiful area then, but I've not been back since.
- Motor Head
02 Oct 2011 18:48maps.google.com/maps?saddr=Springfield,+...src=0&mra=ls&t=m&z=6MFolks wrote: The city of Denver is called the "Mile High City" due to the elevation. When the USAF had Lowry AFB outside of Denver open, I went there during 1966 for a aircraft weapons mechanic school, and every weekend off, took trips up into the mountains. Beautiful area then, but I've not been back since.
Looks like a Boring ride across, but It all changes here, up hill and twisty. The road can take youup to 11K' if you like. Come on over Mike.
- Motor Head
02 Oct 2011 18:52
Back on topic, I can't see why the Popular Dyna System couldn't be made to work. You could run it on just one pick-up coil, as some of you have done on your 4cyl bikes! :laugh:
- 750steve
02 Oct 2011 19:04
Will that replace everything too, i have no knowledge of it!
Interesting facts on your cities lads! :lol:
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
02 Oct 2011 19:09 - 02 Oct 2011 19:10
Igniter box for £20 (so far), free postage too as its local. Is it the right 1 though?
cgi.ebay.com/ebaymotors/Kawasaki-KZ750E-...&hash=item45fd798fcb
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 02 Oct 2011 19:10 by 750steve.
