KZ750 Twin, B2, Electronic Ignition Retrofit
  • loudhvx
  • loudhvx's Avatar
Re: KZ750 Twin, B2, Electronic Ignition Retrofit
03 Oct 2011 23:11
#481264
Man, if coils are that expensive over there, then that will weigh heavy on the decision. I believe he said coils are included in that all-in-one kit.
If points and condenser will add up to more than £25 to £50, then it may not be worth the effort to get the points working.
I would hope that an aftermarket tachometer for a motorcycle should be able to get a signal from the primary side of the coil. That is pretty standard.
Sometimes a Dyna S will not work correctly with some tachs. That is because the dwell is very long and the tach will see that as no-spark, so it won't register a signal.
  • 750steve
  • 750steve's Avatar Topic Author
04 Oct 2011 03:58 - 04 Oct 2011 06:32
#481293
Motor Head wrote: By Clock, do you mean Tachometer? If so it should have a pick-up point on the Negative side of the Ignition coil, which ever system is used.
Offer still stands, if you organize some stuff, you want from the USA. I can compile and ship in One box, to save you a couple of, what Pounds? You use Pounds or Euro's?
Yes, good old rip off Britain is still on £ (pounds), not a bad thing with the way the € zone is going though! I've attached a copy of the clock wiring for you to see, seems straight forward enough & its an all in 1 unit (*Edit*- i cant seem to add .pdf files here) . Tacho, speedo & some warning/signal lights are there too.
Thank you again for your kind offer, i'll see how things unfold.
loudhvx wrote: Man, if coils are that expensive over there, then that will weigh heavy on the decision. I believe he said coils are included in that all-in-one kit.
Yup, its quite expensive to live here! :lol:
The last thing i want to do is come across like a spoilt child that needs to get shot of some money. I've been planning this project for about 18 months now though as the bikes are as scarce as the parts i needed to wait to the right one came up, or the only one! :lol:, so i do have a little money set aside for it (about £1500 so i need to spend wisely). I wasn't waiting on someone to say go get the most expensive IG system cos its better, sometimes that aint the case.
That #5 seems to be a complete kit & if im not mistaken new HT leads are supplied too.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 04 Oct 2011 06:32 by 750steve.
  • bountyhunter
  • bountyhunter's Avatar
04 Oct 2011 04:23 - 04 Oct 2011 04:24
#481294
750steve wrote: Number 1 it is then!
Problem is if you use the old coil, it's a 30 year old coil. :ohmy:
Highly recommend a new one.
Last edit: 04 Oct 2011 04:24 by bountyhunter.
  • 750steve
04 Oct 2011 06:37
#481297
If i do reuse it it'll only be for a couple of months, i'll add a new point & condensor though.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • 750steve
04 Oct 2011 20:39 - 04 Oct 2011 20:39
#481383
Ok, so i bought a point & condensor today along with a couple of other bits. That should tie me over until i get enough gathered up to buy the Optical CDI kit. I figured that right now i've enough to spend!
Frame powdercoat, fabricated alu battery box, shorai battery, instrument clock, maybe rearsets, exhaust cans, headlight, tail/stop light, make a seat unit, lengthen the swingarm. Alot to do!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 04 Oct 2011 20:39 by 750steve.
  • loudhvx
  • loudhvx's Avatar
04 Oct 2011 22:18 - 04 Oct 2011 23:16
#481396
Sounds like a plan. Good luck with the project. It's quite a list you have there. Should be a great bike when you're done.
Last edit: 04 Oct 2011 23:16 by loudhvx. Reason: Typos galore
The following user(s) said Thank You: 750steve
  • 750steve
04 Oct 2011 22:24 - 04 Oct 2011 22:28
#481399
loudhvx wrote: Sounds like a plan. Good luck with the project. It's quite a list you have there. Should be a grat bike when you're done.
Thank you, im quite sure i'll need to consult you in the future if thats ok with you?
I'm trying to get Steell's excellent cheapie rearset trick to work........but boy its frustrating me, i cant figure it out! :lol:
www.armbell.com/forum/viewtopic.php?t=11325&mforum=kz400
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 04 Oct 2011 22:28 by 750steve.
  • bountyhunter
05 Oct 2011 02:43
#481440
I've never seen an exhaust like the one in the picture. Custom?
  • 750steve
05 Oct 2011 03:45
#481445
I have no idea, i bought it like that but someone has obviously added them at a later stage, they're new looking.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
