which dyna ignition for 76 kz750 twin
- 76 kz750
19 Aug 2008 12:09
Hello,
I just got a 1976 kz750. I was told the reason it didn't run was because the points/condenser was bad and that I should replace it. After reading the forums I couldn't find out which dyna ignition will work. Thanks for your help.:dry:
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
Re: which dyna ignition for 76 kz750 twin
19 Aug 2008 12:27
According to the
DYNA
website, the DS2-2 will fit a 750-4. If you have the 2-cyl, I think you are stuck with points.
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
1978 KZ650
2000 ZG1000
- steell
19 Aug 2008 12:39 - 19 Aug 2008 12:41
Limey wrote:
Not necessarily, the KZ440 ignition can be installed on the 750 twin, and aside from finding a used aftermarket ignition, I believe that's the only option now.
I'm pretty sure I have the 440 igniter, plug to adapt it to the 750 wiring harness, and the pickup, don't remember if I have the timing advancer though.
According to the DYNA website, the DS2-2 will fit a 750-4. If you have the 2-cyl, I think you are stuck with points.
Last edit: 19 Aug 2008 12:41 by steell.
- 76 kz750
19 Aug 2008 13:29
Thanks for the info. What all should I replace?
- ronjones
19 Aug 2008 17:26
Hey Steell, can't the IE from the 750 M & K twins, also work?
- Ashbane
19 Aug 2008 18:17
Tag, I have the same bike and need this info as well...
1976 KZ750 B1 Twin
- Ashbane
19 Aug 2008 18:40 - 19 Aug 2008 18:41
Are these the parts from the 82-83 440LTD you're referring to Steell?
From what I can tell about the ignition system it's pretty simple. Battery->coil/points->spark plugs. If this is replacing the points, do we still want to get a Dyna coil or something similar? And whats the difference between the original points and whats coming from the 440?
1976 KZ750 B1 Twin
Last edit: 19 Aug 2008 18:41 by Ashbane.
- steell
19 Aug 2008 21:57
21119, 21148, and 59026 are the parts needed, and they will work with stock, Accel 3 ohm, or Dyna coils. You also need the plug that connects the igniter (21119) to the bike wiring.
Yes, the KZ750K and KZ750M parts will work also, they're just "really" scarce, I have the KZ750M parts on my current 750 twin, the KZ750M motor I bought didn't have the ignition parts, but I had already bought the KZ750M ifnition parts on eBay some time before I bought the motor. I paid ~$40 for the motor on eBay (but had to drive 2 hundred miles one way to get it), but the ignition parts cost me more than the motor did (selling price anyway, cost me another $40 for gas).
- 76 kz750
20 Aug 2008 05:31
There is an ignition kit on z1's site, part# su634-612,.
Is this for the twin or the 4 cyl?
if I search by 750 twin it does not show up, if I search by brand it is there.
Thanks again for all the info as I am new to this motorcycle and would like to get it running as soon as possible but I don't want to buy a bunch of stuff that will not work.
- steell
20 Aug 2008 08:18
I can't find it at Z1 when I search for that part number, but if it's an electronic ignition it's for the 750 four cylinder.
It's definitely not for a 750 twin.
- 76 kz750
20 Aug 2008 09:26
I talked to Z1 and they have 2 kits for the 750 B-1 on back order. I was also told that if I can find parts for it that I should buy whatever I can find because they are scarce.
Anyone have a good source for parts for the 750 B-1 please let me know.
I recommend Z1. They were very helpful and knowledgeable.
No,:laugh: I do not work for them.
- Limey
20 Aug 2008 10:23
Old Bike Barn
has them (they claim), try ordering from them. I see they are the same part for the KZ400 too.
Just don't expect very rapid delivery from OBB - Z1 they ain't - and I think we all agree that Z1 rocks!
Eric
1978 KZ650
2000 ZG1000
1978 KZ650
2000 ZG1000
