shorai lithium batteries
  • Stu Pidasole
  • Stu Pidasole's Avatar Topic Author
  • if you aint mod'n, you aint rock'n!
03 Apr 2011 21:57 - 04 Apr 2011 17:11
#442442
would these work?....... scroll down to videos.
Last edit: 04 Apr 2011 17:11 by Stu Pidasole.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: small batteries
03 Apr 2011 22:20
#442449
Even the recommended size batteries barely get the job done, especially if you have mods in the engine/high compression.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: small batteries
03 Apr 2011 23:45
#442476
TeK9iNe wrote: Even the recommended size batteries barely get the job done, especially if you have mods in the engine/high compression.
Good luck.
B)
That ain't no shit my brand new yuasa struggles. I think I need a high torque starter and an optima. :woohoo:
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • MFolks
  • MFolks's Avatar
Re: small batteries
04 Apr 2011 00:20
#442484
It will help if the battery cables from the terminals are changed to a larger size. 6 gauge welding cable with the correct crimped on terminals increases the current going to the starter motor.
Also the cable going from the Positive(+) terminal to the starter solenoid and from there to the starter motor, don't forget the Negative(-) battery trminal to the engine mounting bolt too.
  • bountyhunter
  • bountyhunter's Avatar
Re: small batteries
04 Apr 2011 02:32
#442506
I think the ballpark is at least 15 Amp-hour. More is better.
  • Stu Pidasole
Re: small batteries
04 Apr 2011 09:29 - 04 Apr 2011 09:33
#442520
something like this work?
Last edit: 04 Apr 2011 09:33 by Stu Pidasole.
  • Stu Pidasole
Re: small batteries
04 Apr 2011 09:35
#442521
  • Stu Pidasole
Re: small batteries
04 Apr 2011 09:44
#442523
  • Stu Pidasole
  • porchev914
  • porchev914's Avatar
Re: small batteries
04 Apr 2011 12:05
#442545
tiny motorcycle battery
I don't think you'll get away with something like that Joe, at least not for long. You could give one of these a shot though!
FRANKEN Z!
  • Stu Pidasole
Re: small batteries
04 Apr 2011 12:15 - 04 Apr 2011 12:16
#442549
porchev914 wrote: tiny motorcycle battery
those are nice adam. doing some reading on them now. whats the cca i should have for the 1000? 200 or more? and can they be laid on thier side?
Last edit: 04 Apr 2011 12:16 by Stu Pidasole.
  • TeK9iNe
  • TeK9iNe's Avatar
Re: A123 lithium batteries
04 Apr 2011 12:16
#442551
The small lithium cells can start a bike, sure, but sucking that much amperage out of that tiny capacitance that quickly = dead/weak cells, VERY quickly. I used to run RC cars off those cell packs we built and they only lasted about 15 minutes.
If you like building and replacing battery packs frequently - go for it.
The reason that the batteries are large is not just for the amperage capacity, but also to act as a buffer/capacitor for the charging system, to help smooth out the power.
There is probly some fancy light/small race approved batteries I might use, but for a street bike...? I dont know.
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
