- Thank you received: 88
KZ 900 warning buzzer NOW WITH PHOTO'S
- GregZ
Is this normal or something faulty. All lights horn hi/beam turn indicators work. However the four way hazzard lights,only the right work,no flashing on left side
cheers
gregz
here is the buzzer
Here is the bike
I have the 26mm carbs off for a good cleaning and decided to test a set of 28's I just rebuilt seems to run A OK
now need some summer. Been long winter
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- MFolks
- Thank you received: 540
I had a 1977 Kz1000 and now own a 1982 GPz1100, neither have this beeper.
As for your 4 way flasher circuit, first check the bulbs, I think #1157 for the front turn signals/running lights and also at the rear for brake/running lights and #1156 for the rear turn signals.
There are two(2) silver colored flasher relays, one for the turn signals and the other for the 4 way hazard light circuit.
- DoubleDub
- Visitor
Bike Bandit schematic has it listed as "ALARM,TURN SIGNAL" and is part #32 on the Chassis Electrical schematic for the '76 900.
www.bikebandit.com/houseofmotorcycles/19...-us/o/m3966#sch40256
The hazards problem is likely unrelated to the buzzer. Mine is doing the same thing and i just haven't had a chance to troubleshoot it.
- GregZ
I'll trouble shoot it, just lookin for quick tip
cheers
gregz
- DoubleDub
- Visitor
It is strange that we are both having the same identical issue.
Can you tell me, do you left/right flasher hesitate on the first flash longer than the others? That's the other weirdness I have. It takes too long for the first blink and then it is normal. Almost like it has to "charge up" for the first flash...but that doesn't make any sense. I thought about replacing the flashers with electric ones from the local farm store, but I'm lazy.
- Thank you received: 2098
THE OTHER ITEM WAS AN AUDIBLE INDICATOR SYSTEM. THIS CONSISTED OF A SMALL ELECTRICAL BUZZER BOLTED TO THE BOTTOM OF THE HEADLAMP SHELL. WHEN EITHER OF THE INDICATORS WAS USED THE BUZZER OMITTED A BUZZING NOISE, NOT UNLIKE THE NOISE FROM A PELICAN CROSSING. WHEN RAIN ENTERED THE BUZZER, WHICH GIVEN THE ENGLISH WEATHER, WAS FREQUENTLY, THE NOISE TURNED TO ONE THAT A STRANGLED CAT MAY MAKE !!. NEEDLESS TO SAY, THE BUZZERS WERE QUICKLY REMOVED BY OWNERS AND DEALERS. IT WAS ALSO NOTED THAT BLIND PEOPLE MAY HAVE CONFUSED THEM WITH THE NOISE FROM PELICAN CROSSINGS, CAUSING CONCERN TO MANY.
Years ago, automotive turn signal beepers were available in several different tunes, including segments from Elvis Presley. A must-have automobile accessory at the time, which complimented the obligatory red fingernail polish painted on interior dash lights.
- testarossa
- Thank you received: 82
The two circuits are independent, I believe. One of the flashers (if I remember correctly) is for left/right and the other is for 4-way. You'll have to dig into the wiring (as will I soon) with a multimeter to figure it out.
I noticed mine doing that just the other day. I just figured that it was a tired flasher. Somehow my rusty original flashers are still doing their thing. When they want to.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- mtbspeedfreak
- Thank you received: 36
Unless you're planning on restoring it (in which case you'll be looking to get rid of your 28's and should let me know ) I highly recommend pulling the beeper off.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- DoubleDub
- Visitor
- mtbspeedfreak
I have a hunch you do; try disconnecting the buzzer (pull out out the headlight to get to the connection) then giving it a try, you should notice that your lights immediately blink when you flip your signals on. This is due to the large amount of current the buzzer draws (which is why it is known to occasionally goes up in smoke).
2000 ZRX 1100
- GregZ
