KZ 900 warning buzzer NOW WITH PHOTO'S
- GregZ
17 Feb 2011 09:47 - 17 Feb 2011 11:54
just picked up super nice 76 kz900. When you turn on blinkers the warning buzzer sounds off BEEB BEEB LOUD!!
Is this normal or something faulty. All lights horn hi/beam turn indicators work. However the four way hazzard lights,only the right work,no flashing on left side
cheers
gregz
here is the buzzer
Here is the bike
I have the 26mm carbs off for a good cleaning and decided to test a set of 28's I just rebuilt seems to run A OK
now need some summer. Been long winter
cheers
gregz
here is the buzzer
Here is the bike
Last edit: 17 Feb 2011 11:54 by GregZ.
- trianglelaguna
Re: KZ 900 warning buzzer
17 Feb 2011 10:04
what no picture......never had a warning buzzer on a kz...dunno
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- MFolks
17 Feb 2011 10:27
Probably something the previous owner added. I don't believe Kawasaki had this feature on their bikes.
I had a 1977 Kz1000 and now own a 1982 GPz1100, neither have this beeper.
As for your 4 way flasher circuit, first check the bulbs, I think #1157 for the front turn signals/running lights and also at the rear for brake/running lights and #1156 for the rear turn signals.
There are two(2) silver colored flasher relays, one for the turn signals and the other for the 4 way hazard light circuit.
- DoubleDub
17 Feb 2011 10:35 - 17 Feb 2011 10:39
My Kz900 had it. Mounts below the headlight. I just disconnected it inside the headlight shell. Doesn't seem to affect flasher operation.
Bike Bandit schematic has it listed as "ALARM,TURN SIGNAL" and is part #32 on the Chassis Electrical schematic for the '76 900.
www.bikebandit.com/houseofmotorcycles/19...-us/o/m3966#sch40256
The hazards problem is likely unrelated to the buzzer. Mine is doing the same thing and i just haven't had a chance to troubleshoot it.
Last edit: 17 Feb 2011 10:39 by DoubleDub.
- GregZ
Re: KZ 900 warning buzzer NOW WITH PHOTO'S
17 Feb 2011 12:08 - 17 Feb 2011 12:10
any idea's why the turn signals work properly but the when you turn on 4 way flashers only the right side work, seems odd
I'll trouble shoot it, just lookin for quick tip
cheers
gregz
cheers
gregz
Last edit: 17 Feb 2011 12:10 by GregZ.
- DoubleDub
17 Feb 2011 12:11 - 17 Feb 2011 12:14
The two circuits are independent, I believe. One of the flashers (if I remember correctly) is for left/right and the other is for 4-way. You'll have to dig into the wiring (as will I soon) with a multimeter to figure it out.
It is strange that we are both having the same identical issue.
Can you tell me, do you left/right flasher hesitate on the first flash longer than the others? That's the other weirdness I have. It takes too long for the first blink and then it is normal. Almost like it has to "charge up" for the first flash...but that doesn't make any sense. I thought about replacing the flashers with electric ones from the local farm store, but I'm lazy.
Last edit: 17 Feb 2011 12:14 by DoubleDub.
17 Feb 2011 12:12 - 17 Feb 2011 12:13
As so elegantly put by Dave Marsden when describing the 1976 KZ900 models ---
THE OTHER ITEM WAS AN AUDIBLE INDICATOR SYSTEM. THIS CONSISTED OF A SMALL ELECTRICAL BUZZER BOLTED TO THE BOTTOM OF THE HEADLAMP SHELL. WHEN EITHER OF THE INDICATORS WAS USED THE BUZZER OMITTED A BUZZING NOISE, NOT UNLIKE THE NOISE FROM A PELICAN CROSSING. WHEN RAIN ENTERED THE BUZZER, WHICH GIVEN THE ENGLISH WEATHER, WAS FREQUENTLY, THE NOISE TURNED TO ONE THAT A STRANGLED CAT MAY MAKE !!. NEEDLESS TO SAY, THE BUZZERS WERE QUICKLY REMOVED BY OWNERS AND DEALERS. IT WAS ALSO NOTED THAT BLIND PEOPLE MAY HAVE CONFUSED THEM WITH THE NOISE FROM PELICAN CROSSINGS, CAUSING CONCERN TO MANY.
Years ago, automotive turn signal beepers were available in several different tunes, including segments from Elvis Presley. A must-have automobile accessory at the time, which complimented the obligatory red fingernail polish painted on interior dash lights.
Last edit: 17 Feb 2011 12:13 by Patton.
- testarossa
17 Feb 2011 12:28
DoubleDub wrote:
I noticed mine doing that just the other day. I just figured that it was a tired flasher. Somehow my rusty original flashers are still doing their thing. When they want to.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- mtbspeedfreak
17 Feb 2011 12:42
The 4-way flashers and turn signal beeper came stock on a 1976 KZ900. I just took mine off the other day, be careful, the turn signal buzzer is known to draw a LOT of current and I have on good account that they will eventually overheat and start smoking.
Unless you're planning on restoring it (in which case you'll be looking to get rid of your 28's and should let me know
) I highly recommend pulling the beeper off.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- DoubleDub
17 Feb 2011 12:42
I'm assuming you mean the delayed flash. Mine is on brand new Emgo flashers from Z1E. And I have another new pair that do the same thing, so it's definitely in the wiring somewhere...
- mtbspeedfreak
17 Feb 2011 12:50
Do the both of you that are discussing the delay from the time you flip on the turn signal to the time the lights blink both have your buzzer wired up?
I have a hunch you do; try disconnecting the buzzer (pull out out the headlight to get to the connection) then giving it a try, you should notice that your lights immediately blink when you flip your signals on. This is due to the large amount of current the buzzer draws (which is why it is known to occasionally goes up in smoke).
2000 ZRX 1100
- GregZ
17 Feb 2011 12:55
The easy thing to do is unplug it. So I 'll get started on the trouble shooting process and fix it !!
