73 z1 dyna installed but...
  • BadAssRX7
  • BadAssRX7's Avatar Topic Author
01 Feb 2011 22:27
#427767
ok we got the 73 z1 up and running with the dyna ing. installed but all the info i have seen around here is dealing with the newer style timing marks thing id call it a rotor i guess. its got a few markes in the 1-4 area and 2-3 area. the old style isnt touched on from what i have seen. I timed it by ear and she still has a spit or sputter but is really close. So i want to know what it should be set at.
at these areas.
no timing advanced?
with timing advanced(motor not running)by holding the advancer full open?
timing advanced with bike running 3500 rpm ish.
when i have it lined up with the 1st mark at idle then rev to 3500 its WAY past the mark at "4" and reading i see 1/4" past the "4" mark id guess an eazy 1/2". Please post pics if you got them.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 73 z1 dyna installed but...
02 Feb 2011 00:22
#427776
  • Old Man Rock
  • Old Man Rock's Avatar
02 Feb 2011 02:50 - 02 Feb 2011 02:52
#427778
This what you looking for?
Maybe this will, help as well, some of the original Dynatek instructions can be confusing....
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 02 Feb 2011 02:52 by Old Man Rock.
  • BadAssRX7
03 Feb 2011 06:53
#428120
this pic did the trick. but when the timing is full advanced its WAY past that mark. any ideas?
and not sure why a gl1000 install sheet might help me out but atleast help was offered. after the wiring for the i900 is done im gonna check/time the ing again
  • PLUMMEN
  • PLUMMEN's Avatar
03 Feb 2011 14:23
#428185
should install same way,only pictures i could find when i googled it.
did you get pm about elongating slots or was that useless info also? :blink:
03 Feb 2011 19:23
#428276
For ignition timing, use only the F mark, and ignore the T mark.
At idle rpm, the F mark should align with the permanent case mark.
Good Fortune! :)
[Click on image to enlarge view.]
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
03 Feb 2011 21:32
#428290
Dyna had a web site at one time, with info, I would call them, they are good people to deal with, just wish their products were as good.
1979 kz 1000 06 katana 750
  • BadAssRX7
03 Feb 2011 22:51
#428296
I didnt say it was useless. But basicly the gl is totally diffrent the coils are 12 34 not 14 23 but atleast you tried to help. I have read about grinding a little on the slots. Im not having a issue with not getting close to time i just needed a more exact picture on the 73 style and lining what up when.
  • Old Man Rock
04 Feb 2011 03:15 - 04 Feb 2011 03:26
#428317
"when the timing is full advanced its WAY past that mark"... Way Past the advance Markings?
For both 1/4 and 2/3 past the advance marks...?
Using a 12Vdc auto light, Static timing come out to spec?
From what I found, if you're on the $$$ in the static adjustment, a very small tweak of each pickup during the 2500rpm was required... hmmm
Out of curiosity, you running stock cams @ 110 LC?
Timing chain exhaust cam pin to intake cam sprocket mark count to spec? Possibly jumped a tooth...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 04 Feb 2011 03:26 by Old Man Rock.
04 Feb 2011 05:26 - 04 Feb 2011 06:11
#428332
Just to confirm understanding that the advancer involved here is the early style oem on 1973 Z1.
F mark should align at idle rpm when using a strobe type timing light (dynamic timing method) or when using a bulb or ohmmeter to determine moment of points opening (static timing method).
May use same timing procedure with Dyna-S as used with points.
The same advancer is still used.
The coil still fires at moment when the primary winding becomes un-grounded.
If a later model advancer has been fitted, it doesn't matter.
Use the F mark and proceed accordingly.
Good Fortune! :)
[Click on image to enhance view.]
Last edit: 04 Feb 2011 06:11 by Patton.
04 Feb 2011 06:04
#428336
NOTE -- The early and late advancers use different Dyna-S rotors.
Early advancer uses a special "3A" rotor with Dyna-S.
Later advancer uses the standard "3" rotor with Dyna-S.
If not already done, would assure that the correct Dyna-S rotor is being used for the particular advancer fitted.
Click > www.z1enterprises.com/detail.aspx?ID=200
Dyna-S Electronic Ignition DS2-1 - Kawasaki Z1 KZ900 KZ1000
DYDS2-1
OEM: DS2-1-
1 year factory warranty - for Kawasaki Z1 KZ900 KZ1000 KZ1100 - set and forget - no more messing with points... creates a stronger more consistent spark
If you have a 73 Z1 or an early 74 Z1A, we may need to supply a different crank rotor. Up through engine number Z1F-32817 kawasaki installed a 5/40 degree mechanical advancer (normal fire mark is 5 degrees then advancing to 40 degrees). If you have one of these on your engine, please enter a note in the special instructions to replace the standard rotor (3 rotor) in the Dyna-S with one special for these early bikes (3A rotor).)
As many advancers have been swapped from bike to bike, please check before ordering.
Good Fortune! :)
  • BadAssRX7
04 Feb 2011 06:06
#428337
CORRECT, FROM WHAT I HAVE READ IT SHOULD BE 1/4" PAST LAST MARK, IM GETTING LIKE 1/2"
CORRECT
HAVE YET TO RECHECK BUT IS ON MY LIST OF STUFF TO DO
I THINK THE MOTORS ALL STOCK GUTS
HAVENT CHECKED YET
