Do I need supression wires?
- MFolks
Re: Do I need supression wires?
12 Feb 2011 11:17
Electrical Connectors, Wire, And supplies
www.easternbeaver.com
www.vintageconnections.com
www.z1enterprises.com/catalog.aspx?pid=KPEL1
www.vehicle-wiring-products.eu
www.electricalconnection.com
www.electricalconnection.com/electrical-components/hitachi.htm
www.pbase.com/mainecruising/wire_termination&page=1
www.crowbarelectricalparts.com/butt_connectors.htm
A good crimped termination is vibration resistant and is gas tight, that is air and moisture cannot intrude causing corrosion and failure.
Soldering is another way of making a connection, the negative part of this method is that the solder usually wicks up inside the wire's insulation making it stiff, prone to vibration failure.
- calvin17d
12 Feb 2011 12:47
TeK9iNe wrote:
I was actually referring to whether my connections to the terminal on that hazard regulator needed to be per a specified terminal or if it mattered. This item is shown as a relay on all 3 of the different diagrams I have reviewed for this year and model.
calvin17d wrote:Good work. I think I have the wiring figured out. Think this is an application from a different year? Any ideas on how I can verify the wiring? Should my choice of terminals matter?
Choice of connectors does not matter, so long as they are good rugged quality, that cannot simply fall apart.
1976 Kz900 A4
