Do I need supression wires?
Re: Do I need supression wires?
11 Feb 2011 19:47
calvin17d wrote:
That's correct. It doesn't matter.
thanks guys, I think I understood that, I guess I was concerned as to whether it mattered which of the spark plug wires say for the 1&4 cylinders coil plugged into the forward or rear input of the coil. I guess it doesnt matter?
Last edit: 11 Feb 2011 19:50 by Patton.
- calvin17d
- MFolks
11 Feb 2011 20:19
Looks like s "Crispy Critter", read this about rectifier problems on some of the early Kawasaki's:
www.redlinecycle.com/rectifiers.html
11 Feb 2011 20:58 - 12 Feb 2011 03:20
calvin17d wrote:
As I recall, the oem regulator was attached under the battery box and the separate rectifier was located under one of the side covers.
I enjoy these combo units from Z1E.
Click > www.z1enterprises.com/detail.aspx?ID=1873
EDIT -- Part # 21066-024 is the Hazard Regulator (not voltage regulator).
Last edit: 12 Feb 2011 03:20 by Patton.
- calvin17d
11 Feb 2011 21:51
My bike is outfitted with the following items. The first item is located under the batter box, the second under the sidecover and the third mounts up to the right side of the battery housing
1976 Kz900 A4
- calvin17d
11 Feb 2011 21:52 - 11 Feb 2011 21:59
anyway, no luck with the pictures....
I was trying to show that my bike is outfiitted with the regulator that is silver and bolts to the bottom of the batter box, it also has the traditional looking rectifier that is black and looks like a series of connected diodes between two plates and then we have the mystery item in the picture above that only has three terminals and appears to be a distribution block of sorts. It does not appear on my diagram but I do know that it was utilized.
1976 Kz900 A4
Last edit: 11 Feb 2011 21:59 by calvin17d.
- calvin17d
12 Feb 2011 03:17 - 12 Feb 2011 03:21
calvin17d wrote:
I also don't see the hazard regulator on the FSM's KZ900-A4 wiring diagram, but the diagram does show the hazard switch and the hazard relay.
Last edit: 12 Feb 2011 03:21 by Patton.
- calvin17d
12 Feb 2011 10:00
Good work. I think I have the wiring figured out. Think this is an application from a different year? Any ideas on how I can verify the wiring? Should my choice of terminals matter?
1976 Kz900 A4
- TeK9iNe
- What did you do!?!
12 Feb 2011 10:49
calvin17d wrote:
Good for you.
Verify the wiring vs. a proper diagram for your bike, which can be found in your service manual... you do have the service manual, dont you ?
Choice of connectors does not matter, so long as they are good rugged quality, that cannot simply fall apart.
Good for you.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
