Band Aid Coil Repowering Mod question
  • otakar
  • otakar's Avatar
Re: Band Aid Coil Repowering Mod question
27 Aug 2010 14:54
#394340
the Dyna ignition consumes just over 6A. Alternators after 79 put out just over 19A pre 79 they put out about 12A
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Motor Head
  • Motor Head's Avatar
27 Aug 2010 16:29
#394355
Thanks otakar, that will tell a lot of guy's what the aftermarket Ignition will draw. Sean here has Installed a 3 phase from a donor 550, or at least I think he did? So 19 AMPs should be the MAX Rated AMP output of the alternator.
  • MFolks
  • MFolks's Avatar
27 Aug 2010 18:04
#394385
I believe www.electrosport.com makes a overwound stator that will have a higher output at low rpm's(I'd check with them for the spec's).
  • seanof30306
  • seanof30306's Avatar Topic Author
27 Aug 2010 19:32
#394423
bill_wilcox100 wrote:
IMHO, I would say MH is right on two counts. First, that 20 Amp would do and second that it is possibly vibration that killed the 3-year old relay and not heat due to current... but just a guess.
Remember, the specifications SHALL be printed on the component. The cheap relay I bought had the following printed on it:
NVF4-2C-Z40a
NO: 40A/14VDC
NC: 40A/14VDC
COIL DC12V
NHG
The "NHG" is just the manufacturer and "NVF4-2C-Z40a" is just the part number, so forget about those numbers.
Again, IMHO, the 40A is the important part. Also, as a rule-of-thumb it’s a good practice to run at only 50% of the rated value or less for long term reliability. The current draw should be less that 10 Amps so a 20 Amp or 40 Amp rated relay should, of course, do the job just fine and for a long time.
Best of success, :)
Bill
OK, great!
So Bill, let's say I walk into the O'Reilly's down the street from me ...
And remember, this is ME ......
What words need to come out of my mouth to cause the guy behind the counter to give over one of those relays?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • seanof30306
27 Aug 2010 19:36
#394425
It's a three-phase from a donor 6 50, an '81 LTD
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • Motor Head
27 Aug 2010 19:40
#394426
Oh I thought it was a 550, oh well. Here try this in the autozone web site and see what you think, Part #19242 radiator fan relay.
  • seanof30306
27 Aug 2010 19:52
#394427
Thanks.
Will it make my bike run any cooler?
www.autozone.com/autozone/parts/Relay-Ra...rchByPartNumber=true
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • Saki Jockey
  • Saki Jockey's Avatar
27 Aug 2010 20:23
#394439
A traditional automotive relay (in the standard package) with a 40A capacity should be an interesting find.
It would also be overkill (sounds like WG). If you follow the schematic, you will see this relay is not cycling with a load on it.
A simple 30A #87 differential relay (standard automotive relay throughout the 80s, 90s) will handle this job for years and years. I prefer Bosch, but won't hesitate to use another brand in a pinch.
Using good quality crimps, crimpers, cable and routing will ensure proper operation and full benefit of the mod.
Killing an afternoon going through electrical connections with a tube of dielectric grease and emery cloth would do wonders as well.
Rob A.
550 A4
GTA,
Ontario, Canada
  • Motor Head
27 Aug 2010 20:27 - 27 Aug 2010 20:31
#394445
Yes 40AMP in the standard 5 1/4" male pins, even 2 pole is available. Just ask at a Auto store or online. Larger I have not seen, that's when such things like Stater solenoids are used, 100AMPs no prob.
Edit: Here is but 1 example;
40 AMP HD RELAY
Product Line: TW DISTRIBUTION
Part Number: TWD MEI1295
Price:
Price
Unit
12.49
Each
Availability:
Call NAPA Store at (719) 574-1650
Warranty Warranty information is unavailable.
Material Safety Data Sheet There is no MSDS for this item
Last edit: 27 Aug 2010 20:31 by Motor Head.
  • seanof30306
27 Aug 2010 20:27
#394446
Thanks Saki Jockey.
If I was to walk into the O'Reilly's down the street, what words would have to come out of my mouth to convince the counterman to give one of those Bosch ones over?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • seanof30306
27 Aug 2010 20:36
#394447
OK, I don't know what any of that means. What do I ask at an auto store or online?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • Motor Head
27 Aug 2010 20:46
#394448
Well it was meant for joe, but that's ok its your thread. So the standard relay the he referred to is a 4 or 5 pin automotive style. It will have male spade connectors coming out of the relay for connecting to. They are 1/4" male spade, you connect with a female of same size or preferably the mating relay socket.
The difference between a single and double pole relay is the 5 pin double pole verity will have the load connection at 2 1/4" male terminals at the same time when the relay closes. #87 & #87a connect to #30 on the bottom of the relay, a single pole will be just that, 30 to 87. A Bosch relay will also have the schematic of the relay printed on the side of it.
