So, Here's The Problem, Any Thoughts/Experiences?
- TeK9iNe
- What did you do!?!
Re: So, Here's The Problem, Any Thoughts/Experiences?
28 Apr 2010 18:05
jeffasaki wrote:
It's a 1-piece solid state. The origional, that came on the bike 30 years ago... :laugh:
Does it have seperate regulater/rectifier? or is it solid state?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
28 Apr 2010 18:10
Just out of curiosity... what is the charging voltage with the bike running?
Are you sure one of the green connector is ideally seated or didn't fall off on the connector panel?
NOTE @ 4Krpm, this is ~ 15-20Vdc and would explain why your seeing such a high DC voltage on the battery after a run thus over charging....
Just in case you need it....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
28 Apr 2010 18:17
Your voltage at the battery WITH BIKE RUNNING should never go over 14V with bike off it should not be more than 12.6V I had this problem on one of my Jaguars years ago and it wound up frying my ignition and coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
28 Apr 2010 18:18
To help confirm diagnosis ---
Could disconnect the charging system altogether and test run as battery-only total-loss ignition.
If problem re-occurs, could likely rule out being due to an over-charging charging system.
- TeK9iNe
28 Apr 2010 18:18
Old Man Rock wrote:
Thats just the thing. I havnt had the chance yet to get a voltmeter on there while its running and revving.
The wiring has been totally re-done, and all connectors are excellent/in place.
Come to think of it, the only component not replaced is the reg/rect unit.
Now that i recall... the turn signal lights start to flash super fast or stay on at high rpm when this starts happening. Guess that should have been a first clue...
Thanks.
Thanks.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
28 Apr 2010 18:21
otakar wrote:
Yeah, I hope my coils/pickups arent fubar!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
28 Apr 2010 18:22
Patton wrote:
Thats a good idea too... hadn't thought that one :blush:
Thanks man!
Thanks man!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- jeffasaki
28 Apr 2010 18:23
OH NO solid state more modern shight just when I was starting to think THE SPOONS was a good band.
anyhow the first thing Id try is swaping out that reg/rect for a known good one.and check all the wires comming from the alternater behind the output drive(you know what im trying to say)also all the plugs under the left side cover.I feel like im preaching to the chior here so let me know
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- TeK9iNe
28 Apr 2010 18:30 - 28 Apr 2010 18:34
jeffasaki wrote:
:laugh: :laugh: :laugh: The Spoons.
Yeah, I guess the reg/rect unit is a gonner anyways.
I'll pick one up at Z1Enterprises on Monday. Its sooo nice living just an hour or so drive away.
Pretty sure the stators ok, but will deffinately run a diagnostic to be sure.
Sometime I just go SOOO frustrated that things arent jsut working! Needed some vent time :laugh: :silly: :laugh:
Thanks all.
Thanks all.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 28 Apr 2010 18:34 by TeK9iNe.
- jeffasaki
28 Apr 2010 18:38
Check all that and when its running good you can sleep in your nova heart
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- otakar
28 Apr 2010 18:38 - 28 Apr 2010 18:39
Believe it or not the original KZ ignition is a better ignition than the Dyna. It actually has some dwell and is much easier on the coils. The Ignition that was designed by "loudhvx" is better yet. That is the one made from the two GM modules. The Dyna was intended to be a points replacement and not an upgrade for the Kawasaki IC ignition. Are you running Green coils or Gray coils?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 Apr 2010 18:39 by otakar.
- jeffasaki
28 Apr 2010 18:42
Ive seen the GM ignition mod and whole heartily agree its a way better upgrade then the dyna however not too many folks know about the GM thing and I think the dyna is bulletproof anyway plus they back up their product
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
