Won't Idle
- ndfez
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Anyways...
The idle adjust knob is attached to the carbs/rack.
It is usually about a 3/4 inch large thumb style screw that you can turn in/out about maybe 8-10 times before it stops or falls out. Turn it in to watch the idle and carb slides increase/lift.
Some have it on the bottom back side. Some on the bottom front... some on the top right. But they all look reletively the same.
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Jodyb17
Is this a set it and forget it screw, or does it need regular attention by design?
1977 KZ 650 C
- JR
- Thank you received: 447
MY KZ750 won't idle any ideas?Were is the idle knob adjuster located at?
If your 750 is an 80 or 81 four cylinder then your idle knob is between carbs 2 nd 3 underneath and pointing down and back. Dont know about twins or later models.
.............and it should be set when well warmed up and forget
- ndfez
- jswag5
- whats the big deal about harley, i prefer 4 cyls!!
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
- ndfez
Thanks for all the help got the 750 to idle,now number 2 an 4 sparkplugs are getting burned black why is this?
jswag5 wrote:
too rich or getting oil in the cylinders.
Possible causes might also include:
-- Weak spark;
-- Wrong size spark plug;
-- Insufficient compression.
- polkat
- Thank you received: 1
