Just did WG wiring mod...is this normal?
- bountyhunter
Re: Just did WG wiring mod...is this normal?
12 Apr 2010 10:27
WABBMW wrote:
Normal, but it sounds like tha battery is either discharged or getting tired.Sorry if I did not explain very well. The readings were with the key in the ON position, otherwise there would be no coil voltage to measure. So, with the engine stopped, and the ignition switch ON, the headlight and parking lights are ON, and the voltage decreases from the 12.5 down to 11.7 due to the draw of the lights. Is this normal?
- loudhvx
12 Apr 2010 15:05 - 12 Apr 2010 15:06
WABBMW wrote:
As Bounty said, considering you have a dyna S, that's not a bad drop at all. Obviously less is better, but with that much current, the main fuse alone could drop near that much.
One thing I noticed about the regulator failures is that they can go gradually. I've had at least two that appeared fine when testing parked, but it wasn't til I ran with a voltmeter attached that I noticed the voltage dropped slowly at a steady high RPM. At around 6000 RPM i watched the voltage go from 14v down to 11 over about a half hour on the highway. Then stopped to idle and it climbed back up. Revved it alittle and it was back to 14v. Got back on the highway and same thing... dropped slowly back down to 11. New (used) reg/rec and the problem was fixed.
You want to try to rig up some voltmeter to the tank and give it a glance on a nice long highway run and see if yours is doing the same thing.
I designed a few idiot lights too if you are into building simple circuits.
Single LED adjustable version
Three LED version
Three LED version
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 12 Apr 2010 15:06 by loudhvx.
