Just did WG wiring mod...is this normal?
- bLodi
10 Apr 2010 13:32
Just finished up the WG coil wiring mod. Went pretty well. I tested my coil voltage last week after a ride and with the engine off and lights off, my voltage at the coils was 11.03. I just tested today after the mod again with the engine and lights off and the voltage was 11.78, so a good bump, the bike hasn't been rode in a week so I expect it will be even higher after. But I am also doing some carb work and won't get a chance to run it until next weekend most likely.
I did notice though now that simply turning my key off does not shut the bikes idiot lights off (oil and neutral.) The kil switch must also be turned off in order to full shut off those lights.....is this normal? Or did I manage to screw something up? I feel I did everything right. I do also have the Dyna S ignition so I did to the extra step at the end of the mod if that has any relevance at all.
Thanks.
Thanks.
www.blodisign.com
\\\\\\\'74 Z1
V&H 4-1 Header, Pod Filters, Dyna Ignition, Dyna Coils, Dyna Wires, lowering kit...much more.
\\\\\\\'74 Z1
- loudhvx
Re: Just did WG wiring mod...is this normal?
10 Apr 2010 15:42
Not normal.
You have something crossed. Don't know what the "extra" is, that you mentioned.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- KZQ
- Administrator
10 Apr 2010 16:09
There's no need to implement a dual electrical system when the stock system needs only basic maintenance. I'm real sure the a .75 volt increase can be realized by just cleaning switch and plug contacts.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- keith1
10 Apr 2010 17:10
last time i checked, my bike gets almost 11 volts and runs like a raped ape.......i did the mod before and the bike didnt run any different...plus i had extra wires i didnt feel like dealing with ....i drank the kool aid once.....
all part of the learning curve.......
- keith1
10 Apr 2010 17:12
loudhvx wrote:
if you do the mod and have dyna s, there is one extra step......it escapes me now, but i remember there was something i had to do....
Not normal.
- Galactica
10 Apr 2010 17:15
I drank the kool-ade too. No difference. An extra unnecessary complication. If the stock wires are good and connections are clean and tight, that's all that's required.
77KZ1000
76 KZ900
76 KZ900
- bountyhunter
10 Apr 2010 17:26 - 10 Apr 2010 17:29
KZCSI wrote:
I am not a user of the relay mod since it is a band aid for something else that needs fixing: either the ig switch, fuse contacts, or a weak coil.
BTW: when your bike is running, the battery voltage is pushed up to 14V which is a 2V increase over the battery's nominal voltage so you get a bigger increase in voltage just by running the engine.
A new coil can do wonders: I recently bought the $36 cheapo EMGO coil from Z1 and my bike starts much easier now. New coils are more efficient than the old stock ones. That will give you more kick than the extra half Volt on the old coil.
+1There's no need to implement a dual electrical system when the stock system needs only basic maintenance. I'm real sure the a .75 volt increase can be realized by just cleaning switch and plug contacts.
Bill
Last edit: 10 Apr 2010 17:29 by bountyhunter.
- otakar
10 Apr 2010 17:31
I also agree. Clean the contacts, fix the problem don't bypass it. This is a band-aid fix.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
10 Apr 2010 17:34
bountyhunter wrote:
ya know something? that was something i was wondering about.....electrical is not my strong suit, but i m figuring if you are checking charging voltage at the battery, and say you get 14.5, and you get 11 flat with just the key on,you should be getting 13.5 to the coils with bike running.....yes/no?.......
KZCSI wrote:+1There's no need to implement a dual electrical system when the stock system needs only basic maintenance. I'm real sure the a .75 volt increase can be realized by just cleaning switch and plug contacts.
Bill
- Old Man Rock
10 Apr 2010 17:35
Bounty (& others) brought up the key component here....
Even in bypassing (:whistle:) with the engine running at ~3K to 4Krpm pending models you should be close to 14Vdc on the battery depicting charging circuit, Dyno, rectifier/regulators working to spec...
Your still 2-3Vdc off the mark so something definitely is not correct pre & post coil mod....
This is the electrical checks & measurements for the KZ900... Should be exact or real close to the Z1 electrical....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
10 Apr 2010 17:36
YES What you get at the battery you should have at the coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
10 Apr 2010 17:53
otakar wrote:
thanks for confirming what i thought.......my edumacation continues......:blink:
