87 KZ1000-P6 coils
  • badr0bot
  • badr0bot's Avatar Topic Author
87 KZ1000-P6 coils
19 Mar 2010 16:09
#354607
I saw the 4ohm coils Bountyhunter mentioned in this post
kzrider.com/index.php?option=com_kunena&...d=4&id=354178#354458
but my coil resistance is 2.4 ohms. The 4ohm coils from Z1 are recommended for points bikes and the 1987 kz1000-P has electronic ignition. Would these OEM 2.4ohm coils be the right choice?
www.z1enterprises.com/detail.aspx?ID=1710
Or is there some logic to using higher resistance coils?
They are $90 each and I want to buy the right pair.
Z1 has a pair of Dyna 3ohm coils for $126. Will they work?
The Dyna coils sound attractive. Does anybody know if It's a good idea to run 3ohm coils on the 1987 electronic pick-ups with 2.4 ohm original coils? Z1 says "It is OK to select coils with a slightly higher resistance." Can anyone corroborate.
87 KZ1000 P1
  • loudhvx
  • loudhvx's Avatar
Re: 87 KZ1000-P6 coils
19 Mar 2010 16:20
#354611
Because the electronic ignitions use less dwell, they need coils with lower resistance to get adequate spark. Ideally you want the same coils which should be about 2.4 ohms. 3-ohm coils should also work if the motor has stock compression. I use mostly 3-ohm coils in place of the 2.4 ohm coils.
I wouldn't go any higher than 3-ohm coils, though. It is safe for the ignition to go higher ohms, but you may start to lose spark energy at higher RPMs.
  • otakar
  • otakar's Avatar
19 Mar 2010 16:27 - 19 Mar 2010 16:53
#354612
The stock coils wer 2.2 Ohm and replacement coils are available either stock or Hi-performance from Dyna (gray coil) I run them in my GPZ and I love the Dyna coils. I run a .060 plug gap and 11:1 compression (1150) Z1E will also have the 2.2 Ohm Dyna coils Part #DC4-1. Just ask Larry. Here is a link to the Z1E page for your coils that you require for that bike.
www.z1enterprises.com/detail.aspx?ID=1306
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 19 Mar 2010 16:53 by otakar.
  • trianglelaguna
  • trianglelaguna's Avatar
19 Mar 2010 18:12
#354652
are you looking to upgrade to a higher quality coil?
cause there are more great used cop bike coils on e-bay than you can shake a stick at.....dirt cheap and complete sets and hangers.......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • badr0bot
20 Mar 2010 15:48
#354944
Will those Dyna coils mount to the same bracket as the stock coils?
87 KZ1000 P1
  • otakar
  • otakar's Avatar
20 Mar 2010 15:55
#354949
I mounted them to the brackets that were on the bike. I only bent them a little to give me easier access.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • badr0bot
20 Mar 2010 16:22
#354962
Awesome.. Thanks Otakar. Gonna order them now.
87 KZ1000 P1
  • otakar
  • otakar's Avatar
20 Mar 2010 16:56 - 20 Mar 2010 17:03
#354981
Make sure that you also order a set of ignition wires to go with them. They are in the same add that I posted for you from Z1E. Don't look for blue ones, I made those myself. I find the best plugs to run are Denso W24ES-U which are coincidently the same as ACCEL 142 I open my gap to .060" but .040 is adequate.
www.summitracing.com/parts/ACC-0142
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Mar 2010 17:03 by otakar.
  • MFolks
  • MFolks's Avatar
20 Mar 2010 19:32
#355024
Before I installed my Dyna Green coils, I noticed the iron laminations were unprotected and could rust.
Being I have some information about electrical items and have built missile test equipment, I got some Glyptol(a high temperature isulating varnish) and painted the laminations ending the potential rust problem.
Coat the lams,let it dry, and then install the coils.
  • badr0bot
20 Mar 2010 21:39
#355069
thanks MFolks, good tip.
87 KZ1000 P1
  • bountyhunter
  • bountyhunter's Avatar
20 Mar 2010 22:36 - 20 Mar 2010 22:37
#355086
Going up from 2.4 Ohms to 4 Ohms would reduce the stored energy due to the shorter dwell time. As stated, it would show up most at very high RPM but I have no idea how pronounced the effect would be. Obviously, since Mother Kawi was already using 4 Ohm coils everywhere in the late 70's when the newer system was phased in, they probably would have stayed with 4 Ohms if they could and not suffer performance loss..... which means I would use the lower coil impedance designed for it. As for used coils off ebay: yeah, I went that route twice and just remember: you are replacing a 30 year old coil that has gone bad with another 30 year coil which is GOING to go bad....:laugh:
Last edit: 20 Mar 2010 22:37 by bountyhunter.
  • otakar
  • otakar's Avatar
21 Mar 2010 06:05
#355111
I believe that Kawasaki,s first lo-impedance system was the KZ1300. The IC igniter was set up for 3 Ohms so Kawasaki put in a 1.5 Ohm coil and also a 1.5 Ohm ballast resistor. That is how they achieved their three Ohms. They than switched to a matched 2.2 Ohm system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
