87 KZ1000-P6 coils
- badr0bot
kzrider.com/index.php?option=com_kunena&...d=4&id=354178#354458
but my coil resistance is 2.4 ohms. The 4ohm coils from Z1 are recommended for points bikes and the 1987 kz1000-P has electronic ignition. Would these OEM 2.4ohm coils be the right choice?
www.z1enterprises.com/detail.aspx?ID=1710
Or is there some logic to using higher resistance coils?
They are $90 each and I want to buy the right pair.
Z1 has a pair of Dyna 3ohm coils for $126. Will they work?
The Dyna coils sound attractive. Does anybody know if It's a good idea to run 3ohm coils on the 1987 electronic pick-ups with 2.4 ohm original coils? Z1 says "It is OK to select coils with a slightly higher resistance." Can anyone corroborate.
87 KZ1000 P1
- loudhvx
- Thank you received: 1616
I wouldn't go any higher than 3-ohm coils, though. It is safe for the ignition to go higher ohms, but you may start to lose spark energy at higher RPMs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- otakar
www.z1enterprises.com/detail.aspx?ID=1306
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- trianglelaguna
- Thank you received: 235
cause there are more great used cop bike coils on e-bay than you can shake a stick at.....dirt cheap and complete sets and hangers.......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- badr0bot
The stock coils wer 2.2 Ohm and replacement coils are available either stock or Hi-performance from Dyna (gray coil) I run them in my GPZ and I love the Dyna coils. I run a .060 plug gap and 11:1 compression (1150) Z1E will also have the 2.2 Ohm Dyna coils Part #DC4-1. Just ask Larry. Here is a link to the Z1E page for your coils that you require for that bike.
Will those Dyna coils mount to the same bracket as the stock coils?
87 KZ1000 P1
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- badr0bot
87 KZ1000 P1
- otakar
www.summitracing.com/parts/ACC-0142
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MFolks
- Thank you received: 540
Being I have some information about electrical items and have built missile test equipment, I got some Glyptol(a high temperature isulating varnish) and painted the laminations ending the potential rust problem.
Coat the lams,let it dry, and then install the coils.
- badr0bot
- bountyhunter
- Thank you received: 337
Going up from 2.4 Ohms to 4 Ohms would reduce the stored energy due to the shorter dwell time. As stated, it would show up most at very high RPM but I have no idea how pronounced the effect would be. Obviously, since Mother Kawi was already using 4 Ohm coils everywhere in the late 70's when the newer system was phased in, they probably would have stayed with 4 Ohms if they could and not suffer performance loss..... which means I would use the lower coil impedance designed for it. As for used coils off ebay: yeah, I went that route twice and just remember: you are replacing a 30 year old coil that has gone bad with another 30 year coil which is GOING to go bad....:laugh:but my coil resistance is 2.4 ohms. The 4ohm coils from Z1 are recommended for points bikes and the 1987 kz1000-P has electronic ignition.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
