Coils
- bill_wilcox100
Re: Coils
14 Jan 2010 15:52 - 14 Jan 2010 15:55
Old Man Rock wrote:
OMR,
Embrace the mod,
Let the mod wash over you,
Be one with the mod,
The mod is the only hope for our future.
Bill :laugh: :laugh: :laugh:
well hell... You could have repaired the original non +13 Vdc issue by the time you wrote all that....:blink: :laugh:
OMR,
Embrace the mod,
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 14 Jan 2010 15:55 by bill_wilcox100.
- TeK9iNe
- What did you do!?!
Re: Coils
14 Jan 2010 16:22
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
mod
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
Re: Coils
14 Jan 2010 17:18
Naw, not worked up but....
Yes, you'll have Battery Vdc on your coils...
Yes your plugs won't soot as bad...
Yes you have added more load to your current demands...
etc....
And hopefully you'll be able to review your non sooted plugs in the daylight for at night..... :ohmy:
Oh that's right, you only have ideal voltage at your coils and in not truly repairing the issue, your headlights are dim at +8Vdc and you can't see well.... :laugh: :laugh:
Oh yeah, and hopefully your battery doesn't drain for your most likely not properly charging it..... Good thing you kept that kick starter.... :woohoo: :laugh: :laugh: :laugh:
etc....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 893cv
Re: Coils
14 Jan 2010 20:49
I have used the Dyna coils for years, good stuff. I have a pair of the green coils on my 1980 LTD. I also use their suppression plug wires, so I dont have to use resister plug caps. The resister caps are not very reliable.
I also recomend the coil mod, the stock ignition system should have used a power relay right from the start. OMR's advice about servicing the stock parts is important too, just remember that you are dealing with a poor design and cheep 30 year old parts.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- loudhvx
Re: Coils
14 Jan 2010 21:14
If it came with a relay on it, my mod would have been to remove it. :laugh:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- timebomb33
Re: Coils
15 Jan 2010 16:03
you need battery voltage at your ignition system if you don't have that, then the coil mod is at best a band-aid. if i dont get battery voltage i'm looking for a bad ground bad connectors something not looking to add any more complexity to and already old and tired system by throwing a bunch of extra wiring and relays at the problem. Keep It Simple Stupid (k.i.s.s) words to live by especally when it come to electrical componets.
I THINK MY POWERBAND BROKE
- fixer5000
Re: Coils
16 Jan 2010 12:44 - 16 Jan 2010 12:46
dyna...and the mod...oops did i say mod?? for the record and its out there on the net wg did not invent the mod...just sayin:woohoo:
1978 kz650b pretty much stock
massachusetts
massachusetts
Last edit: 16 Jan 2010 12:46 by fixer5000. Reason: added info
- bill_wilcox100
Re: Coils
16 Jan 2010 14:56 - 16 Jan 2010 14:58
fixer5000, yes and understood... these relays have been used for automotive use for decades.
"WG" did not invent this for sure. However, for KZRider historical reasons he was an important promoter of this Coil Re-Powering mod as the true cause of a lot of Carb attributed symptoms. He promoted this Coil Re-Powering mod even when it cost his own Carb rebuilding shop some orders. I believe alot of KZ's are still on the road due this single mod... at least that's true for my bike.
So as far as I am concerned, the WG prefix can stay... we honor our own.
No confrontation here... I'm just saying.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 16 Jan 2010 14:58 by bill_wilcox100.
- loudhvx
Re: Coils
16 Jan 2010 19:48
bill_wilcox100 wrote:
Yes, the rest actually made it home.
Just kidding. Couldn't help it... it's an old punch line.
(Usually it starts off as a Harley joke.)
Yes, the mod helps some bikes and is a shortcut to repairing the actual problem. So is plugging a tire with a hole in it. So is cream coating a tank. Etc. Etc.
1981 KZ550 D1 gpz.
Other links.
Other links.
- fixer5000
Re: Coils
20 Jan 2010 16:06
agreed bill..no issues...george is the man either way. i dont care what others may or may not say about him he is one helpful guy here and on his own site too:)
Best of success.
Bill
massachusetts
massachusetts
- Old Man Rock
Re: Coils
20 Jan 2010 16:22
Here we go.... :blush:
The problem is not with George, never has been. Hell the man didn't come up with this wiring, been around quite some time... Like 30 years or so... :blink:
See, everyone believes/feels we have it out for the man where we truly don't... Look at past postings, has 100% nothing to do with George. Never have had any bad words or blow outs with him, never have used his service so can;t comment there, NADA, nothing etc...
The issues Loud, Bounty, myself and some others have with the mod is purely technical, nothing more...
So don't bring George into this for it truly has nothing to do with him.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
Re: Coils
20 Jan 2010 16:47
Old Man Rock wrote:
uuuuhhhhmmmmm......ahhh , forget it.......:laugh:
