Changing out my Gauges for somthing Newer !!
- tsar
07 Jan 2010 09:05 - 09 Feb 2010 06:08
Hey Guys,
I wanted to change the gauges on my 1979 KZ1000ST to something newer,I have a set of Gauges from a 83GPZ (I think) and was wondering if anybody had done this swap and is it difficult.My gauges are mechanical and the GPZ gauges are electrical?
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
______________________
1979 KZ1000ST
2001 HD Sportster 1200
1996 Vulcan 1500
Montreal,Canada
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Last edit: 09 Feb 2010 06:08 by tsar.
- MFolks
Re: Changing out my Gauges for somthing Newer !!
07 Jan 2010 11:24
The Tach is electrical, and I believe it gets signals from the ignition coil(s) primary(small wire side). On some of the Kawasaki's,the speedometer was also electric. On my 82 GPz1100 B2 model, the speedometer is cable driven, so it can vary from year to year.
07 Jan 2010 11:35
My GUESS is that the most difficult part of the swap would be finding a sending unit for the speedo that will work with your wheel/fork combo.
Might be much easier to send the orig units to Z1E for restoration.
- tsar
07 Jan 2010 12:32 - 07 Jan 2010 12:46
The set of Gauges I have are from an 83 GPZ 750 and are completely electrical.Is there is a sensor or something that my Speedo Cable can plug into that would translate the signal to the electrical Speedo on the GPZ unit. I like this set of Gauges and think it would look cool on my older KZ.How did the GPZ unit get its speed signal? Was it from the wheel to a speed sensor or from somewhere else? Maybe it can be converted to fit my application ,Totally Custom.Just Thinking out loud here guys.Any Thoughts as to if this can be done. I have seen some old KZ's with custom gauges at shows and they looked pretty cool.
I found this online its for a car but maybe will work.I just don't know if the speedo will be true, I could live with it being off by 10 kph up or down.
S9013 Universal Speedometer Sending Unit Kit
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Last edit: 07 Jan 2010 12:46 by tsar.
07 Jan 2010 13:32
Kawi's with electric speedo's had a sending unit that took the place of the driven gear at the front wheel. From there, wires went to the speedo. You can easily see it in the parts diagram for a 1982 LTD 1000
www.kawasakiepc.com/SystemSearch_Frames....529&CFTOKEN=55696521
- tsar
09 Jan 2010 09:54
I found this on the net,It's from KOSO they say it will fit any bike and it comes with all the brackets and speed sensor .Does anyone have any experience with these gauges?
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- oldkaws4ever
- Have no regrets...... You only live once.
09 Jan 2010 12:28
I havent ever seen that before......way awsome. That is a perfect idea for my kz 650. That is idenical to the stock speedo/tach set up on my gsxr 1000. Is that a shift light in the top right ontop of the speedo?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- otakar
09 Jan 2010 16:41
The tach is simple. I did it to mine when I lost my tach drive by using a GPZ head. The spedo, just pick up a GPZ spedo drive on eBay. i bought on for about $20. You might have to change your axle and wheel bearings dependent on if your bike uses the large or small axle to match the hole in the spedo drive.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
09 Jan 2010 16:43
No eBay APP ID and/or Cert ID defined in Kunena configurationI just found this one on eBay. It is more than I paid for mine but still not bad.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
09 Jan 2010 16:45
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is another.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- supercharged
10 Jan 2010 01:43
I like the KOSO and available through Parts Unlimited, so dealers and ebay will have them. Wondering how the speed pick-up is accomplished.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- Old Man Rock
10 Jan 2010 03:01 - 10 Jan 2010 03:04
If interested...ACEWELL Speedo's....
www.electrosport.com/street/speedometers.php
Speed sensing several ways... but most are inductive or magnetic pick ups...
If you research into OEM specs on newer bikes, they pick up or count cc sprocket tooth counts in the tranny gear box areas.
Easiest, magnet on the front rotor...
Tach, conductor soldered into a coil primary feed...
Speed... Provided rotor magnet and fab up a mounting bracket...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 Jan 2010 03:04 by Old Man Rock.
