Changing out my Gauges for somthing Newer !!
  • tsar
  • tsar's Avatar Topic Author
Re: Changing out my Gauges for somthing Newer !!
12 Feb 2010 15:05
#347934
Do you have to disconnect the oil sensor when you change the oil? Also, I notice that it has a fuel gauge...did your kz1000 come with one or did you have to create one for your bike?
Yes, you disconnect the oil sensor when changing the Oil and My ST came with a fuel gauge.If you do not have a sending unit in your tank ,You will not be able to hook up the fuel Gauge.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβέ
______________________
1979 KZ1000ST
2001 HD Sportster 1200
1996 Vulcan 1500
Montreal,Canada
  • jeffasaki
  • jeffasaki's Avatar
12 Feb 2010 15:18
#347936
C C C C COOOOOOOL Im getting one
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
12 Feb 2010 15:48 - 12 Feb 2010 15:50
#347941
tsar wrote:
In the video, the tach says your bike is idling at around 400rpm it looks. Whats up with that?
Can you set a max rpm/redline?
Can you calibrate/change tach ratio?
Ya it's fully adjustable and the rpm say 400 because of the new carbs ,They are not fully dialed in yet and manage to stay running a 400RPM.
In my garage, a large Kawasaki four running steady at a true 400 rpm would likely evoke a call to Guinness. :laugh:
Good Luck! :)
Last edit: 12 Feb 2010 15:50 by Patton.
  • larrycavan
  • larrycavan's Avatar
12 Feb 2010 17:03
#347947
Awesome guage!
I have an Acewell like OMR's. The only thing I wish is it was about 50% larger.
  • kzr750r1
  • kzr750r1's Avatar
13 Feb 2010 07:01
#348018
larrycavan wrote:
Awesome guage!
Agreed they are out of scale a bit.
I need to get some speed indicator on my bike. The governator is looking to CHP to balance his books with traffic fines.:angry:
Thanks for sharing looks like a nice unit.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • Old Man Rock
  • Old Man Rock's Avatar
13 Feb 2010 07:18
#348021
"The only thing I wish is it was about 50% larger."...
WHoa, my wife just said the same thing... :blush: :laugh:
Larry and I discussed this for they are a small unit of sorts but they do work extremely well... ;)
For the Acewell or similar units, you could always buy a Dakota casing for example and fab it in for larger appearances... Or have one machined out of aluminum for you guys...
Could be done but this stuff is expensive... :S
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
13 Feb 2010 10:25
#348065
Good Luck! :)
:laugh: :woohoo: :laugh: My thoughts exactly!!! There is deffinately some combination of things here... gauge not calibrated correctly + idle very low...
Whatever. It still looks great :P
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • tsar
14 Feb 2010 19:33 - 14 Feb 2010 19:37
#348335
Ye of little Faith.
When I get everything dialed in properly I will post another video for the Non Believers.
:laugh: :) :laugh: :) :laugh:
AND YES THE BIKE IS RUNNING AT 400 RPM's.LISTEN TO IT!!!
These new Carbs are da Bomb.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβέ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
Last edit: 14 Feb 2010 19:37 by tsar.
  • Old Man Rock
15 Feb 2010 04:19
#348405
Drooooooooooooool! Well done! B)
Up the idle to at least 800 for oil circulation...
As for the CRS... yup they do ROCK!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
