- Thank you received: 1
ignition switch
- rosken
- Kawickrice
- Thank you received: 18
To get to the filebase scroll to the top of the page go to KZ information-filebase. Hope this helps you
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- rosken
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Bluemeanie
- Thank you received: 14
Without knowing what you have it will be difficult to help you. You may have a control unit from a different brand bike or you may have a K&S unit. Kawasaki color codes all of their bikes exactly the same. For example: black and yellow is always a frame ground Brown is always Live Ground Etc.
Don't mean to interupt but what is the difference between frame ground and live ground? My switch also has the separate brown wire. I have a nice switch (no extra brown wire) off a 78 but won't work on mine and never see ones on ebay with the extra brown wire which mine also has. My tumblers are so loose that key falls out hitting bumps so I need another one.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
- Thank you received: 1616
I found out the hard way about live ground. It is actually a positive wire. It is for example used on things like most sending units, horns, oil pressure and neutral lights, to name a few. If it is a SOLID BROWN wire, it is a POSITIVE ground. If it is YELLOW & BLACK it is a negative frame ground. BLACK & WHITE is a intermittent or switched ground and BLACK is a main switched ground. While, YELLOW & BLACK is a permanent ground. If it is coming from your switch controls it may be a HORN wire or a ENGINE KILL SWITCH wire, or even a brake lever wire. Brown is also used with your fuel gauge, Electronic Speedometer and electronic Tach.
I've never heard of a positive wire being called a "positive ground" when there is already a negative ground. That kind of defeats the whole concept of "ground" being a reference point for all relative voltages doesn't it?
I've only heard of positive ground when a system uses a battery's positive terminal tied to the frame/engine. It seems what you are referring to is simply a "live" wire. It has 12 volts on it relative to ground (when the ignition switch is on).
(Incidently, my wiring harness had black/white wires tied to black/yellow wires, and some black wires, so I'm not sure how absolutely consistent the color codes are. Also, the starter relays are wired with a black/white as a switched positive and the ground was a yellow wire.)
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
My only question is where do you get the term "live ground" to mean the same as a "live wire". The only time I see the terms "live" and "ground" used togethter is when someone is using it as notation to mean "live-to-ground". Usually this is only used in household AC situations. For example, if someone wanted to indicate that a wire was 120 vac relative to ground they would say the wire was "120 vac live-ground". This is to differentiate from when a wire is 120vac relative to another phase. In houses with 220vac, one live wire can be 120vac relative to ground (120vac live-ground) or it can be 220vac relative to the other live wire.
Is it possible this is where you got that term?
1981 KZ550 D1 gpz.
Other links.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
- Thank you received: 240
- rosken
