Free Bike Givin To Me
- ndfez
22 Oct 2009 15:57
I have a 1981 Kawasaki Kz750 that was givin to me,Question I have is how do u get the rest of the starter off the bike,do I need to purchase a special tool of some sort?Or just ol fashioned elbow grease.I took the two bolts off an the housing came off just the end is still stuck in there.Please help newbie in need off help before wife gets mad.Thanks
- lapeerray
Re: Free Bike Givin To Me
22 Oct 2009 16:40
The bike is junk at this point, the starter is not replacable. Just give me the bike and youll be out nothing.
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- ndfez
- Grantl
- KZRider is Da Bomb!!!
22 Oct 2009 19:00
Why did you think you needed to take off the starter motor?
What were the symptoms? What model 750 is it? 4 cylinders or 2. Can you bump start the bike? Does the engine run?
The more information you can give us, the better advice we can give in return. If, after we give you good advice, the bike still doesn't run, then consider Lapeeray's advice.
Best of luck,
Grant.
Best of luck,
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- JR
22 Oct 2009 19:23 - 23 Oct 2009 06:56
If it's the 750/4 then the starter motor should be on the left side. Remove the gear change foot lever. Remove the 4 bolts that hold the sprocket cover/casing in place. Remove the sprocket cover. Just behind cylinders 1 & 2 is the chrome rectangular shaped cover for the starter motor. Take that off. The starter motor looks like a cylinder. Pull it out. When it is partway out turn it over and undo the nut that attaches the power wire.
Good Luck
Edit - forgot to mention there should be a bubber boot over the nut
Good Luck
Last edit: 23 Oct 2009 06:56 by JR.
22 Oct 2009 19:46
If you're going to keep the bike or do much work on it you should consider buying the Kawasaki factory service manual. They're generally available on eBay, just be sure to get the one for your exact year/model. They really are worth their weight in gold. Good luck with your "new" KZ. Ed
PS Don't forget to get a couple (small scale and larger scale) torque wrenches if you don't already have them. It's important to use them so you don't strip the threads in the aluminum engine.
- ndfez
23 Oct 2009 07:13
This bike is a 750 4 cylinder,I have no idea if it runs,I know the motor is not locked up which is half the battle,the starter was already out an missing alot of parts,so bought a used one,don't want to put alot of money into her yet,until I know she starts.So how do I get the last half out to put my used one in?
- ndfez
23 Oct 2009 10:18
I got it off finally little wiggling it an a little ol'fashion elbow grease she came off.
- lapeerray
23 Oct 2009 17:11 - 23 Oct 2009 17:13
ndfez wrote:
hey welcome aboard.
Cant blame a guy for tryingUr funny,I know the bike is not ruined nice try
Last edit: 23 Oct 2009 17:13 by lapeerray.
- MFolks
23 Oct 2009 19:37
Some starter rebuild websites:
1. www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
2. www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm
- ndfez
31 Oct 2009 10:04
I was out in the garage today trying to get the bike to start an couldn't,first she would crank but not turn over an white smoke coming out of the exhaust.Second I looked at the spark plugs #1,#3,and #4 were good,but #2 was black,why is that?Third gas was coming out the bottom of my carbuertor does this mean need new one or new gaskets?An finally in my oil sight glass there was white substance I could see,is this gas,an if so how did it get in there?Oh before I forget is it normal for starters on these bikes to chirp while trying to start the bike?Please help me wife getting mad.
- timebomb33
31 Oct 2009 12:00
needle and seats would be a good place to look for your fuel leakage and if there is gas in the bottomend start looking there. no 2 plug could be fouled. he white substance could be from condesation buildup i have seen that lots in the past and you got the bike for free what has your old lady got to bitch about. that is the reason i never got remarried and why i freakin rent from time to time.
I THINK MY POWERBAND BROKE
