Free Bike Givin To Me
- keith1
Re: Free Bike Givin To Me
04 Nov 2009 15:53
thats why i like vm series carbs.....simple albeit a little antiquated......they get the job done and come in small,medium and large.....:laugh: ....had a set of bs 34...way too finicky and complicated for my neanderthal cranium...:laugh:
- ndfez
04 Nov 2009 16:34
Cool gonna try it whats the worst that could happen buy new diaphrams which I need anyway.
- ndfez
06 Nov 2009 13:45
I got a dumb question were is the oil filter located on these 81 Z 750?
- MFolks
06 Nov 2009 14:09
I'd think it would be located much like the bigger 4's are located. Look under the bike, there should be a round cover with a bolt holding it to the engine. Next to it will be the oil drain bolt.
The normal oil change procedure is to get the engine oil nice and hot,and drain the oil. Some aluminum foil can be used to keep the oil off the exhaust system if there is a clearance problem.
After the oil is drained, take a wrench to the cover bolt and the oil filter will be attached to the bolt.I think the bolt takes a 19MM wrench(could be wrong).
Check the condition of the O rings, especially the large one on the cover. When installing a new filter, put a little fresh oil on the O rings for a good seal. The filter may come with new O rings.
- ndfez
06 Nov 2009 15:01
I took out the round cover with the bolt,but no filter inside alot of oil but no filter,wonder why there was no filter in there that baffles me.
- keith1
06 Nov 2009 16:41
ndfez wrote:
there are a lot of hacks out there who figure "old bike, screw the filter, i m sellin' it anyway"....get a filter and make sure you have the spring and washer.....minor stuff....
- ndfez
06 Nov 2009 17:10
So there should be a spring in were the oil filter should be?keith1 wrote:
ndfez wrote:I took out the round cover with the bolt,but no filter inside alot of oil but no filter,wonder why there was no filter in there that baffles me.
- ndfez
06 Nov 2009 17:11
woops new to this quote thing next time put my message on the bottom
- keith1
06 Nov 2009 17:27
there is on the big bikes...i dont see why the smaller ones should be different......kawasaki.com has all the schematics you will ever need.....shows part numbers and general layout....very informative and can answer a lot of questions....not driving you away, but a good place for self edumacation.....
- ndfez
06 Nov 2009 18:10
Yeah that Kawasaki.com thing dosen't work for me says can't find my bike,plus I have a shop manual from Kawasaki coming to me,so the old wise man one said;paitence is a virtue
- keith1
06 Nov 2009 18:25
ndfez wrote:
dont give it too much info.....hit motorcycles, then hit year, then it will give you a list.....your cc's wont be exact, just hit the cc class...if its a 750, it will show something like 768 cc cruiser......try it again....
- keith1
06 Nov 2009 18:31
try this link and when it opens hit "click here"...i got right in.....good luck
kawasaki.com/DefaultFrame.aspx?strConten...81%26SHOWVEHTABS%3d1
