Where the heck is the starter clutch?????
  • cricketfire46
  • cricketfire46's Avatar Topic Author
19 Oct 2009 20:43
#328511
Ok, starter is replaced... Oil pan plug finally fixed... Starter now sounds like it is free spinning, It was suggested by members that I fix any worn parts on the starter clutch, looked on Kawasaki website and cant quite figure out where this alleged clutch is located. Any help appreciated
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
  • cricketfire46
Re: Where the heck is the starter clutch?????
19 Oct 2009 20:43
#328512
Wow it worked, didnt think I would actually be able to put the diagram up here... Who knew
  • MFolks
  • MFolks's Avatar
19 Oct 2009 20:56
#328515
On the Z1's,Kz900's.Kz1000 and 1100's the starter clutch is located behind the alternator rotor. If your bike is the 750 twin, I believe it's inside the engine cases.
For 750 twin information look here:
www.armbell.com/forum/viewforum.php?f=43&mforum=kz400
If you have the four cylinder bike:
kz.mbsween.com/manual.html
  • bountyhunter
  • bountyhunter's Avatar
19 Oct 2009 23:20
#328535
The 750 twin starter clutch is right under the flywheel rotor. Don't have to split the cases to get it off..... thank god, they fail frequently on the twins.
  • timebomb33
  • timebomb33's Avatar
20 Oct 2009 11:45
#328597
the parts down in the right had corner of the parts diagram that aren't circled are the ones you need to be looking at.you will probably need part no 922122 x 3 and pn. 12046 the ringgear on the bearing surface flat spots and the rollers do as well.
I THINK MY POWERBAND BROKE
  • RonKZ650
  • RonKZ650's Avatar
20 Oct 2009 15:56
#328622
According to his signature it must be a 4 as it's got a 4 into 1 pipe which I doubt fits on the twin.:P
On the four you can either pull the engine or lay on your back for several hours. I'd pull the engine.
  • rstnick
  • rstnick's Avatar
20 Oct 2009 17:46
#328640
You can also drain all the fluids, remove the battery, tank side cover/s etc and lay the bike on it's side on top of a couple of tires.
This makes working from below much esaier:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • cricketfire46
20 Oct 2009 17:52
#328641
sorry guys, been busy at work today. It is a 4, need to add that part to my signature. When I started this I had no clue there was a 750 twin, I was an under informed noobie. When I pulled the oilpan I somehow or another managed to wiggle my 220 lb self under the bike just like working on my Jeep. How much time will this take? Is this going to be something that can easily screwed up I am mechanically inclined, but if I am not 100% I can screw it up. Or is this just a good chance to get down into the motor? Another factor with me is shop space, If this requires pulling internal parts that must stay "sterile" i may have an issue because I literally do shade tree work. If it wont be very expensive or is extremely complicated I will pay to have this done.
  • N0NB
  • N0NB's Avatar
  • Blue handles better
21 Oct 2009 04:21
#328704
You will have to remove the oil pan and clutch cover along with the clutch itself (basket and all). The only problem I had when I did one was seating the right side bearing in the case. Kawasaki says to remove the gear off the end of the secondary shaft before reinstallation but I was lazy and left it on. So I used a long slender punch to tap the bearing into place. The factory service manual has a good writeup of the procedure.
Between the info here and on kz650.info I think you'll be able to do it. Allow yourself a few days to do it and buy new gaskets along with the rubber O-rings that fit between the oil pan and the cases.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • cricketfire46
22 Oct 2009 17:25
#328999
Trying to figure all this out still, just went for about a 3 hour ride. Cold start was a little tricky. When I did get it running, noticed that the clutch (the transmission not the starter) had no play in it. I adjusted this back to normal. after stopping for fuel, and food, had no problems with starting. Are the clutch and starter clutch somehow tied together??? or was the motor being warm what caused this???
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
26 Oct 2009 10:31
#329733
Starting clutch and tranny clutch are not related. The air cooled, carburated engine starter easier because it was warm.
  • cricketfire46
26 Oct 2009 19:37
#329856
thanks on the info with the 2 not being related, Hopefully tomorrow will be dry and I can tear into it tomorrow. Not a huge fan of having rain water inside the motor, that would lead to way too many new questions on here...
