Ignition system on '77 kz650
  • eaglecrash2
  • eaglecrash2's Avatar Topic Author
17 Nov 2008 21:08
#248042
I have a 77 kz650 since new. Has 32k miles on it but recently brought it out of storage. Since one cable on the factory coil broke off I replaced both with Accel coils for CDI system as recommended by a Kawasaki tech. I had also replaced the points with a Martek 440 points when bike was new so the Tech said that I have a CDI system. With the Accel coils the bike ran well for 100 miles or so and then the left coil for no. 2 & 3 cyl crap out. Put on a good set of factory coils from a '78 kz650 and the left coil is still not functioning i.e. 2 & 3 cyclinders are not firing. I felt like the Accel coils were incorrect which might have ruined the Martek 440. Any advice? Should I replace with the Dyna S that i read elsewhere in this forum? Is the Martek 440 still available? Thanks for any help here.:angry:
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
  • timebomb33
  • timebomb33's Avatar
Re: Ignition system on '77 kz650
17 Nov 2008 21:35
#248057
i don't think the martek is available any more looks like your options are to replace it with a dyna ignition and i don't think the accels hurt the martek. ive had a couple of martek's thru the years and i think the marteks hurt the martek they wern't that good.
I THINK MY POWERBAND BROKE
  • eaglecrash2
17 Nov 2008 21:46
#248062
Which Dyna in particular will be appropriate for my bike. I can't wait to fix this darn thing so as to start riding again. Thanks
  • Mark Wing
  • Mark Wing's Avatar
17 Nov 2008 22:14
#248069
I have a Dyna S on my 77 650.
Mark
Yorba Linda Cal.
17 Nov 2008 22:33
#248073
For consideration:
Dyna-S from Z1E
Good Luck! :)
  • eaglecrash2
17 Nov 2008 22:38
#248076
Thanks folks. I just ordered a Dyna s on line. I read the installation instructions and it's pretty straight forward. Will let you know the results.
  • bountyhunter
  • bountyhunter's Avatar
18 Nov 2008 15:46
#248157
eaglecrash2 wrote:
Put on a good set of factory coils from a '78 kz650 and the left coil is still not functioning i.e. 2 & 3 cyclinders are not firing. I felt like the Accel coils were incorrect which might have ruined the Martek 440. Any advice? :
usig the socalled "high performance" coils (which have a lower primary resistance than stock) will blow out some CD ignitions. The peak current being asked of the CD's storage capacitor is too high and the capacitor fails over time. Most CDI's will work well with stock coils assuming they are not blown out previously by a low impedance coil.
  • bill_wilcox100
  • bill_wilcox100's Avatar
18 Nov 2008 19:27 - 18 Nov 2008 19:28
#248191
EC2, I ride a '77 KZ650-B1 and I installed Dyna S this summer. Works great. I don't know why I held out so long... must have been the money! :laugh:
See my signature below for the part numbers of the Dyna S and matching Dyna coils I got from Z1 Ent.
Best of success. :)
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 18 Nov 2008 19:28 by bill_wilcox100.
  • timebomb33
18 Nov 2008 19:33
#248193
dyna s or dyna can't go wrong with ether one.all i have used for years set them and forget them. when i get a bike with points they don't stay on it for long.
  • loudhvx
  • loudhvx's Avatar
18 Nov 2008 23:48
#248263
Martek made CDI systems, but I'm pretty sure the Martek 440 is not CDI. As I said in the other thread, if you used low-resistance coils on the Martek 440, it may be blown.
Have you measured the resistance on the Accel coil's primary side?
  • eaglecrash2
19 Nov 2008 18:35
#248398
Just had the chance to measure the Accel coils- one coil has 3.5ohms & the other has 0.8ohms on the primary. Both. secondary reads 11.5ohm. It's obvious one is shot.
19 Nov 2008 19:12 - 19 Nov 2008 19:14
#248408
Coil might indeed be shot, but am thinking coil primary ohm measurement is best made with wiring to both terminals being disconnected. That is to say, with both the battery positive wire and ignition signal wire both being disconnected. I could be wrong. :S
Good Luck! :)
Last edit: 19 Nov 2008 19:14 by Patton.
