BI-XENON HID CONVERSION KIT H4
- RoyNor
Re: BI-XENON HID CONVERSION KIT H4
01 Mar 2008 09:19Please Log in or Create an account to join the conversation.
- otakar
01 Mar 2008 09:35
I just bought a H4-2 set for a car and got in essence two motorcicle kits for $72 including shiping from Hong Cong. But I decided that I did not like the shifting bulb idea and bought the dual bulb set instead. There are two bulbs mounted on the same socket. The Lo beam is xenon and the Hi is Quartz. Since I almost never use the Hi Beam, that is just fine for me. Here are some pictures of the single kit I bought before.
Post edited by: otakar, at: 2008/03/01 12:47
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Rickman
01 Mar 2008 09:39
N0NB wrote:
JC Whitney has a HID kit $466. painful..
But they also have a halogen kit for $45, so you could start there then go for the abovementioned chinese shipper clipper kit to make it HID.
www.jcwhitney.com/Motorcycle-Headlights/600014816.jcw
My 83 L1 has a 7" halogen bulb reflector, so 'stock' parts may be an option for you as well.
Edit: Oh I see Tsar's price for a reflector from Cycle-recycle is cheaper than the JCW price..
Post edited by: Rickman, at: 2008/03/01 12:54
I'd appreciate a pointer or two to a turnkey solution for the KZ650 or any bike with a 7" round bulb. Remember, that I need to replace a sealed beam unit with a lense shell.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- otakar
01 Mar 2008 09:50
You should be able to find a "Semi-Seald" lens either on eBay or from one of the noumerous suppliers. They are available since no one uses sealed beams any more. Here is a shot of the dual bulb. Check Bike bandit Or Ron Eyers.
Post edited by: otakar, at: 2008/03/01 12:59
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
01 Mar 2008 13:19
Here you go Rickman. Here is a link for the lense or should I say lenses you will get two since it is a conversion for a car.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...em=370026417202&rd=1
Once you have this just install the Xenon kit. Here is a picture of the Dual bulb Xenon conversion XenonLo/HalogenHi.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
01 Mar 2008 13:31
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- tsar
01 Mar 2008 20:59
Hey Otakar
Does your kit have a positive, negitive hookup to your battery or is it a direct plug only in to the 3 prong where the bulb normaly plugs in.
(Just the 3 prong to the ballast to the bulb no battery hook-up)
In the pic it looks like there is red & black wires going to your 3 prong plug.I'm just curious as to the difference from the kit I got from HK.Please keep me posted after you hook up your kit I'm curious to see your light in action. If it is a better kit I'll recommend it to the guys I ride with.
Thanx
Post edited by: tsar, at: 2008/03/02 00:00
Post edited by: tsar, at: 2008/03/02 00:06
Thanx
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
______________________
1979 KZ1000ST
2001 HD Sportster 1200
1996 Vulcan 1500
Montreal,Canada
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- Royal1MC
- Is it just me, or is it just great to be on a KZ
12 May 2009 16:15
I have question regarding this kit. After I installing the system and took the bike for a ride I notice my headlight failure light on. I also notice the headlight flickering as I was riding, I was wondering if this is normal or has this happened to anyone else. I have a 1980 Z1-R. It has the reserve lighting device, could that be an issue with the flickering.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Los Angeles, CA
- Just Yourshadow
- Just taking life as it comes...
12 May 2009 20:55
I've had experiance with HIDs doing that. It's either poor voltage or poor ground. I recommend doin a WG coil mod and running a straight ground to the battery to stop the flickering. As for the failure light your guess is as good as mine
1976 KZ900A4
Kerker 4 into 1, Andrews 2X intake Cam, K&N Dropin Filter.
1982 Kz550-H1 GPz
1982 Kz550-H1 GPz
- otakar
13 May 2009 04:25 - 13 May 2009 04:28
Yes, your problem is the reserve lighting device. This device MUST be bypassed. You can blow the ballast on the HID. My system is a direct plug in. I just plug it in to my three prong connector where the old bulb plugged in and that is it. You can see the installation in my thread on page 15.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 13 May 2009 04:28 by otakar.
- Royal1MC
13 May 2009 06:57
I've contacted Xenonlink HID System Inc. regarding the issue, their sending me a "special harness" supposedly for a more stable current, so I have to wait and see. I will look into the reserve lighting to by pass it.
Otakar, I did see the trend. I have the same 3 prong connector with in the system. I like the clear lense look.
Los Angeles, CA
Los Angeles, CA
