Removing tank rust
  • XL777
  • XL777's Avatar Topic Author
Removing tank rust
17 Jul 2006 09:27
#62608
Hey what sould I use to remove minor fuel tank lining rust?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
  • mariozappa
  • mariozappa's Avatar
Re: Removing tank rust
17 Jul 2006 11:01
#62636
Do a search in the archives.
There are about half a dozen different ways to do it.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
19 Jul 2006 10:43
#63164
Very small steel ball bearings.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
19 Jul 2006 12:35
#63185
I do not bother with removing minor rust inside a tank. It's easier to clean the petcock screen and install a fuel filter and check periodically.
-Duck
  • wireman
  • wireman's Avatar
19 Jul 2006 12:54
#63188
-Duck
yep!;)
  • amedeo
  • amedeo's Avatar
19 Jul 2006 16:27
#63219
foot of chain.put inside and shake. then clean with acetone be fore lining.
  • amedeo
  • amedeo's Avatar
19 Jul 2006 16:28
#63220
P.S. make sure you put string on end of chain to remove and keep it from sticking inside
  • OKC_Kent
  • OKC_Kent's Avatar
19 Jul 2006 16:57
#63223
I used a foot of chain, taped up the holes, poured in a pint of tile&grout cleaner (phosphoric acid) and shook around. Use a coat hanger to fish out chain. Rinse with water then some light oil.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • OKC_Kent
  • OKC_Kent's Avatar
19 Jul 2006 16:59
#63224
Cashion, OK
  • kawtoy
  • kawtoy's Avatar
19 Jul 2006 17:24
#63227
I like to use Muratic (spelling?) acid. 3/4 tank of water and the rest acid. Let it sit and hour then turn on each side a bit to let it get to the top of the tank. Don't tilt too far or the water/acid will come out of the fuel cap. Yes it will eat the paint if you leave it on there. I usually pour water over the tank as I am adding the acid just in case some splashes out. The acid will also etch the tank. Dry it out as fast as you can using a hairdryer or compressed air. After you drain it the tank will start to flash rust so the sooner you get it dry the better. I would stay away from the tank liners. I have heard many horror stories about them. I have my tank lined but It didn't take very well and it looks like crap. Unless you really know what you are doing it will cause more harm than good. Lite rust in the tank is not all that bad. Only bad part is that you can not see all parts of the tank so some areas might be worse than others. Clean it with some acid and add an in-line filter and you will be just fine. If you want to see the acind work first then find a metal or glass jar or something and fill it 3/4 water and 1/4 acid. Drop a rusty bolt in and let it sit for awhile. The jar or can will start to get hot as the acid reacts to the rust and metal. Take it out and then you will see how well it works. Later
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • trippivot
  • trippivot's Avatar
20 Jul 2006 06:35
#63350
C.L.R. works like magic
kreem kit
muratic acid then get oil in there or it will rust up again
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
21 Jul 2006 02:39
#63574
Insert chain, nuts ,bolts etc,etc in tank. Wrap in blanket and insert in wifes dryer with no heat. Tumble until clean.
Do this when you are home alone.
And make sure there is no gas in tank. Roy
