Leaking out of overflow
- Glockers1963
Re: Leaking out of overflow
01 Aug 2026 11:30
Got a box containing a spare set of carbs and looks like 1 carb rebuild kit still sealed I’ll take a look tomorrow ,
was hoping for advice on easiest way to remove carbs so I could investigate thanks again for your help
1980 KZ650 CSR
- Maxbou92
01 Aug 2026 12:09 - 02 Aug 2026 04:25
Thats more job to access to the carbs with Oem Air box.. take your time to remove all and inspect your Boots to the engine. With age they crack !! Find a rebuilt kit for all 4 carbs before you open them, just to be sure that you didn’t do the job twice!!
Kz750e 1980
Last edit: 02 Aug 2026 04:25 by Maxbou92.
- Glockers1963
01 Aug 2026 12:49
- asphalt900
02 Aug 2026 04:15
If you've not found out yet? You have the late (air screw) VM24ss Mikuni Non-pumpers. If it's just one bowl overflowing then it could be just a speck of dirt or a cracked overflow tube? Open the bowl slotted brass drain screw on leaking carb. Let petrol flow out with petcock in ON position. This will wash out any loose debris between needle and seat, hopefully. Reinstall screw and see what happens? If it still is stubborn and leaking then further investigation required. Technically there is enough room to remove everything without having to remove carb rack but it's tight and small fingers required. If it turns out to be a bum float needle and seat then you'll be needing a Mikuni VM26/26 float set, probably a 2.3 opening but could be a 2.0. Seat gasket is Mikuni VM26/25. I always just purchase OEM Mikuni parts but Keyster will work too.
The following user(s) said Thank You: Glockers1963
- Glockers1963
02 Aug 2026 04:33
Absolutely outstanding advice,
will try this tomorrow as it’s Sunday today and I’ve got an appointment with a large rum and coke and a cigar that should tie me up for a couple of hours!
Thanks again to everyone on this forum for all their input you really helped with diagnosis and potential solutions 👍
1980 KZ650 CSR
- asphalt900
02 Aug 2026 05:08
You have the discipline to just have ONE Rum and Coke?? Ha.
- Glockers1963
02 Aug 2026 05:09
Oh don’t worry it’s a very large one 😂😂
1980 KZ650 CSR
