Leaking out of overflow
  • Glockers1963
  • Glockers1963's Avatar Topic Author
01 Aug 2026 09:15
#926356
Back again guys for more information,(help)
Got bike running after refitting sump and replacing oil filter and new oil , bike seems to be running fine but there’s always a but !
when I stop the second carb from the right is pissing fuel out of the bottom!
I think the float is stuck ?
Suppose this means I’ll have to take carbs off and investigate but not really sure of the best way to go about it
I struggled for about 2 hours to get airbox rubbers in and reluctant to take them back out
can carbs be removed and still leave them in place?
they are brand new rubbers so are quite plyable
any help would be very much appreciated
1980 KZ650 CSR
  • Maxbou92
  • Maxbou92's Avatar
Re: Leaking out of overflow
01 Aug 2026 10:35
#926358
Have you check your float level with clear
tube method?
Kz750e 1980
  • Glockers1963
01 Aug 2026 10:41
#926359
I am a complete novice so not exactly sure what that means , sorry to sound stupid
1980 KZ650 CSR
  • Maxbou92
  • Maxbou92's Avatar
01 Aug 2026 10:47
#926360
What carburetor you have?! Look on google “ float clear tube Method”
Kz750e 1980
  • Glockers1963
01 Aug 2026 10:51
#926361
Thanks I’ll do that not sure of carb I will take a photo later and see if anyone can identify it for me 👍
1980 KZ650 CSR
  • Maxbou92
  • Maxbou92's Avatar
01 Aug 2026 10:52
#926362
You got a 650 csr 1980 ?!
Kz750e 1980
  • Glockers1963
01 Aug 2026 10:54
#926363
Yes I do
1980 KZ650 CSR
  • Maxbou92
  • Maxbou92's Avatar
01 Aug 2026 10:55
#926364
I guess they are mikuni BS ?!
Kz750e 1980
  • Glockers1963
01 Aug 2026 11:08
#926365
These are fitted to bike
1980 KZ650 CSR
  • Maxbou92
  • Maxbou92's Avatar
01 Aug 2026 11:15
#926366
To me they look Vm26. Fuel should be 3mm under float gasket. Look how to to it on google/youtube 😊
Kz750e 1980
  • Glockers1963
01 Aug 2026 11:17
#926367
Job for tomorrow thanks for your input cheers👍
1980 KZ650 CSR
  • Maxbou92
  • Maxbou92's Avatar
01 Aug 2026 11:23
#926368
Maybe your float needle is worn due to age?! So fuel level is out of spec. I use for my VM carburetor Ebay Rebuilt kit.. Keyster made them!!
Kz750e 1980
