Leaking out of overflow
- Glockers1963
01 Aug 2026 09:15
Back again guys for more information,(help)
Got bike running after refitting sump and replacing oil filter and new oil , bike seems to be running fine but there’s always a but !
when I stop the second carb from the right is pissing fuel out of the bottom!
I think the float is stuck ?
Suppose this means I’ll have to take carbs off and investigate but not really sure of the best way to go about it
I struggled for about 2 hours to get airbox rubbers in and reluctant to take them back out
can carbs be removed and still leave them in place?
they are brand new rubbers so are quite plyable
any help would be very much appreciated
1980 KZ650 CSR
- Maxbou92
Re: Leaking out of overflow
01 Aug 2026 10:35
Have you check your float level with clear
tube method?
tube method?
Kz750e 1980
- Glockers1963
01 Aug 2026 10:41
I am a complete novice so not exactly sure what that means , sorry to sound stupid
1980 KZ650 CSR
- Maxbou92
01 Aug 2026 10:47
What carburetor you have?! Look on google “ float clear tube Method”
Kz750e 1980
- Glockers1963
01 Aug 2026 10:51
Thanks I’ll do that not sure of carb I will take a photo later and see if anyone can identify it for me 👍
1980 KZ650 CSR
- Maxbou92
- Glockers1963
- Maxbou92
- Glockers1963
- Maxbou92
01 Aug 2026 11:15
To me they look Vm26. Fuel should be 3mm under float gasket. Look how to to it on google/youtube 😊
Kz750e 1980
- Glockers1963
01 Aug 2026 11:17
Job for tomorrow thanks for your input cheers👍
1980 KZ650 CSR
- Maxbou92
01 Aug 2026 11:23
Maybe your float needle is worn due to age?! So fuel level is out of spec. I use for my VM carburetor Ebay Rebuilt kit.. Keyster made them!!
Kz750e 1980
